Activity Forums Adobe After Effects Creating a Light Tunnel (in Zaxwerks?)
  • Creating a Light Tunnel (in Zaxwerks?)
    Posted by Jeffrey Fitzgerald on December 1, 2005 at 11:58 pm
    I am working on a project that needs a tunnel of vertical light beams shimmering in a 3D circle. The effect is used a lot on news stations.
    I’m thinking of an extruded disc in zaxwerks with a layer map. Does this sound right? Any ideas are appreciated.
    Michael Szalapski replied 20 years, 9 months ago 3 Members · 2 Replies
  • Chris Zwar
    December 2, 2005 at 11:15 am
    Maybe I’m thinking of something different, but CC cylinder or CC sphere should be easier to use. Start with a flat composition with a 2:1 ratio, eg 1000×500, create a flat version of your light beams, then apply the cc cylinder effect and adjust the settings to suit.
    -Chris Zwar
    Motion Graphics Designer
    Will animate for food
  • Michael Szalapski
    December 2, 2005 at 9:14 pm
    Why not use Polar Coordinates? Animate a bit of fractal noise scaled big time in one direction and then Polar Coordinates it! Put a circular mask in the center to make it more tunnely.
    Would that do it?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
