Activity › Forums › Apple Final Cut Pro Legacy › creating a letterboxed DVD from FCP
  • creating a letterboxed DVD from FCP
    Posted by John Ms on August 29, 2007 at 7:12 pm
    Hello,
    I need to create a 16:9 ratio DVD from a standard 4:3 DV NTSC video. What I’m doing is:
    1. Exporting the video from FCP using Compressor to a default DVD 4:3 mode and and then cropping 10% (48 from 480) off of the top and 10% off of the bottom for my letterbox mode.
    2. After bringing the “cropped” file into DVD StudioPro, I set the default display to letterbox and make my DVD.
    Does this sound like the best way to proceed? I want to have the DVD play full screen on wide screen monitors and generate letterbox black bars if someone watches on an older 4:3 television set (with of course no distortion).
    Thanks in advance for any help and advice.
    John
    Jurij Magoga replied 19 years, 1 month ago 2 Members · 1 Reply
  • Jurij Magoga
    August 30, 2007 at 6:44 am
    i think you should create a16:9 anamorphic sequence in FCP, put your 4:3 video in, then scale it up to fill the width of the 16:9. (you could use some scaling plug in instead of FCP own motion tab, like red giant instant hd maybe, for bette r scaling results.)
    then export the sequence in a 16:9 video.
    put it in DVD Studio Pro track and in the attribute panel select Display mode > 16:9 -letterbox
    Doing so your video fits a 16:9 screens without distorsions and is letterboxed in 4:3 screens
