Activity › Forums › Adobe Premiere Pro › Creating a GoPro file to put back on the camera
  • Creating a GoPro file to put back on the camera
    Posted by Matt Stoltz on December 20, 2023 at 5:24 pm
    Hi
    Not sure where I should post this but does anyone know what settings to use to compress a video so that you can put it back on the GoPro card and have the camera read it.
    I have a very stealth mission. My little one is determined to catch Santa on video and I wanted to jazz up the video after I record it and put the video back on the GoPro. I just cant figure out the correct compression setting to use in Media Endcoder so that the GoPro will read it.
    Any help is appreciated
    Eric Santiago replied 2 years, 9 months ago 2 Members · 1 Reply
  • Eric Santiago
    December 20, 2023 at 10:41 pm
    Which GoPro?
    They have an app you can dissect the format from.
    Probably Google it as well.
    The other part is just naming it according to their naming convention.
    Or just just record it from a playback screen.
    Good luck.
