Activity › Forums › Maxon Cinema 4D › Creating a field of postcard images
  • Creating a field of postcard images
    Posted by Kevin Camin on February 22, 2012 at 5:43 am
    I am trying to figure out how to make a field of 100 flat, postcard images for a camera to fly through.
    I’m considering a cloner object with 100 individual null children, each containing: a plane, external compositing tag and compositing tag. I would assign each of the 100 nulls a different buffer for After Effects, where I would add the images.
    Is this the best way? There probably a less agonizing way to do this.
    Best regards,
    Kevin Camin
    Kevin Camin replied 14 years, 7 months ago 3 Members · 4 Replies
  • John Macenroy
    February 22, 2012 at 10:28 am
    Hi Kevin,
    if I was to do it I would first try to use the MoGraph Multi-Shader in Combination with a Random Effector on a Cloner object to achieve your goal.
    First make a Cloner object to create your Post Cards, then connect a Random Effector to this cloner object and disable Position changes. Turn on Color Mode and set it to add. Then create a new material and select MoGraph->Multi-Shader in the drop down menu of Color. Click on it and for shader 1 choose the first picture of your library with the postcards. Then click on the picture and choose calculate. The Multi-Shader now loads all the pictures in the directory because he thinks it’s a sequence. Now click the arrow up to get into the Multi-Shader properties again and hit “to layers” he will insert all the other pictures of the library and attach the material to your cloner object.
    Hope this helps
  • Kevin Camin
    February 23, 2012 at 2:58 am
    Thanks for the detailed tut, John, I really appreciate it.
    I did get stuck though:
    I created the Cloner Object, attached a Random Effector to it, and disabled Position Transform parameter.
    I created a new material and selected MoGraph->Multi-Shader in the drop down menu of Color. I then clicked on it and loaded the first picture from the Finder into Shader 1.
    I clicked on the picture. Here is where I had a problem. I could only find the Calculate button under the Animation tab so I clicked it there.
    I then hit the up arrow and selected ‘to layers’. I applied the material to my object within the Cloner. I enabled the Position parameter in the Random Effector.
    The only image that appeared was the one that I selected from the finder and half the postcards are a blank, bright white.
    Any additional guidance would be much appreciated. I’m using R11.
    Best regards,
    Kevin Camin
  • Tim Shetz
    February 23, 2012 at 4:13 am
    Not to talk you out of using Cinema, but is there a reason you don’t just do it IN after effects?
    __________
    Tim Shetz
    c4dtraining.com
  • Kevin Camin
    February 23, 2012 at 4:29 am
    It’d like to get some glossy reflections on the postcards from the environment to add a little something extra. And I might play around with the Random Effector to have them collapse together at the end.
    Best regards,
    Kevin Camin
