creating a FC Pro effect in Avid with Boris
Posted by Julian Semilian on July 6, 2011 at 5:07 pmHello,
Thanks for looking into this. I recently started using Avid again after years of Final Cut Pro There is an effect in FC called Indent which I need to use. I have BCC 3 on my Avid.
Also, I am looking for something similar to Color Emboss.
I am using MC5 on a MacBook Pro 10.6.6 and 3.06 Intel Core 2 Duo Processor.
Many thanks,
Julian Semilian
Julian Semilian replied 15 years, 2 months ago 2 Members · 6 Replies -
Peter Mcauley
July 7, 2011 at 12:20 amHi Julian,
For Indent you can find a matching result if you use BCC Bump Map. You’ll probably only need to adjust the filters bump height parameter for most clips.
For Color Emboss, you can get a match if you use BCC Emboss. Select the OverlayOnOriginal preset from the factory installed presets and you should be good to go.
I hope this helps!
Cheers,
Peter.
Julian Semilian
July 7, 2011 at 12:35 amThank you, Peter!
I will try these tomorrow and send you a message on how it worked. Much appreciated!
All the best,
Julian
Julian Semilian
July 7, 2011 at 6:31 pmHi Peter,
Thanks for the suggestions. The Bump Map worked like a charm and I had immense fun playing with the controls. I did get the effect I wanted, and much better than I expected.
Regarding “BCC Emboss. Select the OverlayOnOriginal preset from the factory installed preset”: I could not find the OverlayOnOriginal preset. As I mentioned I have BCC 5. Is it possible it is not on it?
All the best,
Julian
Peter Mcauley
July 7, 2011 at 6:59 pmHi Julian,
I’m glad that worked out for you. I’ve uploaded the preset that I mentioned in my post, which may have been from a more recent version of the software – you can download it here:
https://f1.creativecow.net/2536/preset-emboss-filter?uploaded=file
Cheers,
Peter.
Julian Semilian
July 7, 2011 at 11:02 pmDear Peter,
Thank you profusely! I really appreciate it. I will give you a report tomorrow.
All the best,
Julian
Julian Semilian
July 8, 2011 at 6:35 pmHi Peter,
It worked like a charm. Thanks again.
I am in the process of moving all my projects to Avid from FC. I had already created a large number of files in FC using Indent and Color Emboss. But what I can do with Boris looks delightfully better. So, I am re-doing all that work now with Boris in Avid. Fortunately, I don’t have a strict timeline, I make experimental movies with lots of effects and layering. I spent many years in my career as an editor cutting on film. Then in the nineties moved to Avid, after which I began teaching editing at the University of North Carolina School of Filmmaking. I started using FC for my own experimental projects but in the last few weeks moved back to Avid. I am very grateful to Boris for creating such wonderfully imaginative effects, allowing me to make the sorts of projects I have only dreamed about all my wife but couldn’t make because the technology wasn’t there, of if it was, would have been cost-prohibitive.
All the best to you,
Julian
