Activity Forums Apple Motion Creating a dotted path with an object
  • Creating a dotted path with an object
    Posted by Faraz Mozafarian on December 23, 2009 at 1:40 am
    Hello,
    I am sure this is a very simple question for most of you out there. I wanted to create an animation similar to a planes path over a map where the path is a dotted/broken line. But instead of the path being small dots I wanted the dots to be made up of an image I have.
    How would I go about doing this?
    Thank You in advance!
    Bill Mclellan replied 11 years, 4 months ago 3 Members · 3 Replies
  • Faraz Mozafarian
    December 23, 2009 at 2:00 am
    Never mind. I figured it out. 🙂
    Thanks Anyway.
  • Mark Spencer
    December 23, 2009 at 2:53 pm
    Read up on how to use the Replicator, it’s the tool you want to use. Basically:
    1) Draw a path with the bezier shape tool
    2) Replicate your image
    3) Set the Replicator Shape to Geometry
    4) Drag your path to the well
    5) Use a Sequence Replicator behavior to animate the replicated images along the path.
    Here’s a tutorial:
    https://www.motionsmarts.com/tutorials/drawinglines/drawinglines1.html
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Bill Mclellan
    May 8, 2015 at 6:06 pm
    So, will this create the same effect of marching ants? I am trying in Motion to have a dashed line continuously move. I have gotten a dashed line to move with a rate behavior and adjust the offset. I really can’t control the speed of the movement. Any help would be greatly appreciated.
