Activity Forums Adobe Illustrator Creating a “dotted-line” effect
  • Creating a “dotted-line” effect
    Posted by Mr.inker on March 1, 2007 at 9:42 pm
    I need to create a “dotted line” around an ad we made for newspaper print. I need this dotted line to outline the ad to create a “cut-out” coupon look. Like, you would cut along the dotted line. The ad is already done, so if you could answer on how to create it as well as how to add it to the already done ad, I would be most gratefull.
    Inker
    Mr.inker replied 19 years, 2 months ago 2 Members · 4 Replies
  • Mike Gondek
    March 2, 2007 at 5:12 pm
    You defintely would want to do this in illustrator over photoshop
    Quick Method
    Draw a rectangle the size of the coupon
    In strokes palette turn on dashed line
    Method for perfect corners
    Draw a rectanngle the size of a dash on bottom left
    Option drag a copy to bottom right
    Create a blend between both and specify the number of steps
    Alt Drag a copy to the top
    Repeat same process for the sides.
    Dashes at corners should overlap at 90 degrees rotation to get an L shape
  • Mr.inker
    March 2, 2007 at 5:44 pm
    Thanks Mike. I am having a problem finding hte strokes palatte, could you point me inthe right direction? Thanks. I am using PS7, I do not have Illustrator.
  • Mike Gondek
    March 5, 2007 at 3:31 pm
    Sorry the strokes palette is only exists in Illustrator, photoshop has a stroke layer style, but that will be of little use.
    You might as well set a line dashes in arial, rasterize this then duplicate that for the opposite end, and and erase to make the shortened sides.
  • Mr.inker
    March 5, 2007 at 6:19 pm
    That’s what i ended up doing. It served the purpose. Thanks again.
