Activity Forums Adobe After Effects creating a dance floor like this
  • creating a dance floor like this
    Posted by Tommaso Cicognani on May 15, 2009 at 11:14 am
    hi everyone,
    I wonder if someone could help me in creating a dance floor like that one you see on this music video:
    https://www.youtube.com/watch?v=d4lPA5G0DOo (Kylie minougue’s video)
    In the video there are 2 different type of dance floor:I’m trying to recreate both!
    What I find the most difficult is the one that appears first in the video (light strings changing colous).
    Thanks in advance for the help
    Tommaso
    Brian Charles replied 17 years, 4 months ago 4 Members · 3 Replies
  • Michael Szalapski
    May 15, 2009 at 2:09 pm
    The first one would be the easier of the two in my opinion. Just use the generate>beam effect. Several layers with the beam effect applied with a bit of stylize>glow on the layers themselves and the appropriate amount of glow added over top for some light spill over the actress should get you close to the desired effect.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Roland R. kahlenberg
    May 15, 2009 at 2:25 pm
    The pipes should be easy with Effect>Beam and the change in intensity/hue can be done with Colorama.
    Lots of options for this one.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Brian Charles
    May 15, 2009 at 7:40 pm
    RoRk is correct, the Beam Effect will work.
    To help you set it up in perspective create 2 solid layers, apply Grid and adjust settings to taste.
    Make 3D and rotate 90 degrees in the X axis and pull one up and the other down. Use the grid lines to align the animation of the Beams. Each beam will be a separate layer.
