Activity Forums VEGAS Pro Creating a custom render list?
  • Creating a custom render list?
    Posted by Paul Gregory on May 16, 2011 at 2:38 am
    When it comes to rendering out a project I find that it’s confusing because there are so many choices most of which you will never use. I was wondering if there is any way to edit this list of options so that it displays only those options you might use? For instance most PAL users are unlikely to want to see NTSC options (unless they have a need to recall them). Alternatively can the list be sorted or flagged in some manner? Could you create a custom list
    Any suggestions along these lines would be much appreciated.
    Thanks in advance
    John Rofrano replied 15 years, 3 months ago 2 Members · 1 Reply
  • John Rofrano
    May 16, 2011 at 3:39 am
    There is no way to create a custom list. You could delete the ones you don’t want. Vegas Pro will place an equal sign (=) in front of those templates that match your project properties so it does make it easier to pick one out and it will remember the last one that you used so you shouldn’t have to select it each time unless you keep switching formats.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
