Activity Forums Avid Media Composer Creating a Caption File
  • Creating a Caption File
    Posted by Zach Worden on January 13, 2016 at 4:22 pm
    I need to create a caption file (preferably .scc) for a feature length documentary. Almost all of the dialogue is subtitled already. We used the Title Tool to create those subtitles. Is there a way to create a .scc from the subtitle track of my Media Composer sequence?
    Zach
    Michael Phillips replied 10 years, 8 months ago 2 Members · 3 Replies
  • Michael Phillips
    January 13, 2016 at 4:29 pm
    Unfortunately there is no way to export the text content of the title tool as a format that can be parsed. That is why using SubCap is sometimes the better option for subtitle creation as it allows for the text to exported as text with timing (DS Caption file) or STL (EBU-N19). From there it can be parsed by different applications as a starting point for Close Captioning. And although SubCap exports EBU-N19, it does not support the full spec -so while it exports the text, it will not preserve position, font, color, etc.
    Michael
  • Zach Worden
    January 13, 2016 at 4:32 pm
    Okay. Thanks.
    Zach
  • Michael Phillips
    January 13, 2016 at 5:13 pm
    for all the nerds out there that want to see what the AAF holds – here is a dump file using AAF Dumper of a sequence that has nothing but a single title in it – no video, no audio, just the title. The title is comprised of two text boxes as seen in this screenshot:
    Here is all the info inside the AAF file (a binary file) and nowhere amongst the reams of metadata will you find the text from the title. If you could, one could create an AAF parser to a subtitle format. I believe it can be reverse engineered from some of the data in the file (see: AvidBagOfBits), but it is not easy and probably not something someone is going to take on as it has little ROI for a third party to do:
    AAF DLL path name: C:\AAF DUMPER\AAFCOAPI.dll
    AAF DLL version : 1.1.6 (6995)
    Dump of file: C:\AAF DUMPER\title only.aaf
    ################## Summary Information #################
    File has 6 mobs
    File has 0 EssenceData objects
    ######################## Header ########################
    ByteOrder: 18761
    LastModified: Jan 13, 2016 16:39:16.00 GMT
    Version: { 1, 1 }
    IdentificationList: Strong Object Reference Array [1] of Identification
    kAAFTypeID_IdentificationStrongReferenceVector [0]:
    [ Identification ]
    CompanyName: “Avid Technology, Inc.”
    ProductName: “Avid Media Composer 8.5b40115”
    ProductVersion: { 8, 5, 0, 0, VersionBeta }
    ProductVersionString: “Unknown version”
    ProductID: { d0b7c06e-cd3d-4ad7-acfb-f03a4f42a231 }
    Date: Jan 13, 2016 16:39:15.00 GMT
    ToolkitVersion: { 1, 1, 6, 8865, VersionUnknown }
    Platform: “AAFSDK (Win64)”
    GenerationAUID: { 3605cb41-c910-4e5d-a095-36cc27031810 }
    ObjectModelVersion: 1
    ######################## Mobs ########################
    [ MasterMob ]
    MobID: 060a2b340101010101010f00-13-000000-{ 56967d89-b107-0919-060e-2b347f7f2a80 }
    Slots: Strong Object Reference Array [2] of MobSlot
    kAAFTypeID_MobSlotStrongReferenceVector [0]:
    [ TimelineMobSlot ]
    SlotID: 1
    SlotName: “”
    Segment:
    [ EssenceGroup ]
    DataDefinition: Picture
    Length: 2877
    Choices: Strong Object Reference Array [1] of SourceReference
    kAAFTypeID_SourceReferenceStrongReferenceVector [0]:
    [ SourceClip ]
    Length: 2877
    SourceID: 060a2b340101010101010f00-13-000000-{ 56967d89-b108-0919-060e-2b347f7f2a80 }
    SourceMobSlotID: 1
    StartTime: 0
    EssenceGroupType: 1
    PhysicalTrackNumber: 1
    EditRate: { 24000/1001 }
    Origin: 0
    kAAFTypeID_MobSlotStrongReferenceVector [1]:
    [ TimelineMobSlot ]
    SlotID: 2
    SlotName: “”
    Segment:
    [ EssenceGroup ]
    Length: 2877
    Choices: Strong Object Reference Array [2] of SourceReference
    [ SourceClip ]
    Length: 2877
    SourceID: 060a2b340101010101010f00-13-000000-{ 56967d8a-b5a8-0919-060e-2b347f7f2a80 }
    SourceMobSlotID: 1
    StartTime: 0
    kAAFTypeID_SourceReferenceStrongReferenceVector [1]:
    [ SourceClip ]
    Length: 2877
    SourceID: 060a2b340101010101010f00-13-000000-{ 56967d8b-b77c-0919-060e-2b347f7f2a80 }
    SourceMobSlotID: 1
    StartTime: 0
    EssenceGroupType: 1
    PhysicalTrackNumber: 2
    Origin: 0
    LastModified: Jan 13, 2016 16:38:35.00 GMT
    CreationTime: Jan 13, 2016 16:38:33.00 GMT
    UsageCode: Usage_LowerLevel
    ConvertFrameRate: False
    MobAttributeList: Strong Object Reference Array [1] of TaggedValue
    kAAFTypeID_TaggedValueStrongReferenceVector [0]:
    [ TaggedValue ]
    Value: (indirect type: aafString) “__AttributeList”
    TaggedValueAttributeList: Strong Object Reference Array [11] of TaggedValue
    [ TaggedValue ]
    Value: (indirect type: aafInt32) 1
    kAAFTypeID_TaggedValueStrongReferenceVector [1]:
    [ TaggedValue ]
    kAAFTypeID_TaggedValueStrongReferenceVector [2]:
    [ TaggedValue ]
    Value: (indirect type: aafInt32) 0
    kAAFTypeID_TaggedValueStrongReferenceVector [3]:
    [ TaggedValue ]
    kAAFTypeID_TaggedValueStrongReferenceVector [4]:
    [ TaggedValue ]
    Value: (indirect type: aafInt32) 2
    kAAFTypeID_TaggedValueStrongReferenceVector [5]:
    [ TaggedValue ]
    kAAFTypeID_TaggedValueStrongReferenceVector [6]:
    [ TaggedValue ]
    kAAFTypeID_TaggedValueStrongReferenceVector [7]:
    [ TaggedValue ]
    kAAFTypeID_TaggedValueStrongReferenceVector [8]:
    [ TaggedValue ]
    Value: (indirect type: aafString) “__PortableObject”
    PortableObject:
    [ NetworkLocator ]
    URLString: “file:///C%3A/Users/Public/Documents/Shared%20Avid%20Projects/title-0919a023.PICT”
    PortableObjectClassID: 1464421958
    kAAFTypeID_TaggedValueStrongReferenceVector [9]:
    [ TaggedValue ]
    kAAFTypeID_TaggedValueStrongReferenceVector [a]:
    [ TaggedValue ]
    AppCode: 1
    [ SourceMob ]
    MobID: 060a2b340101010101010f00-13-000000-{ 56967d89-b108-0919-060e-2b347f7f2a80 }
    Slots: Strong Object Reference Array [1] of MobSlot
    [ TimelineMobSlot ]
    SlotID: 1
    SlotName: “”
    Segment:
    [ SourceClip ]
    Length: 2877
    SourceID: 060a2b340101010101010f00-13-000000-{ 56967d89-b182-0919-060e-2b347f7f2a80 }
    SourceMobSlotID: 1
    StartTime: 0
    Origin: 0
    LastModified: Jan 13, 2016 16:38:33.00 GMT
    EssenceDescription:
    [ CDCIDescriptor ]
    Locator: Strong Object Reference Array [1] of Locator
    kAAFTypeID_LocatorStrongReferenceVector [0]:
    [ NetworkLocator ]
    URLString: “file:///C%3A/Avid%20MediaFiles/MXF/1/title1452703113V056967D89.mxf”
    SampleRate: { 24000/1001 }
    Length: 1
    ContainerFormat: MXF
    Compression: { 0e040201-0204-0100-060e-2b3404010101 }
    StoredHeight: 1080
    StoredWidth: 1920
    SampledHeight: 1080
    SampledWidth: 1920
    SampledXOffset: 0
    SampledYOffset: 0
    DisplayHeight: 1080
    DisplayWidth: 1920
    DisplayXOffset: 0
    DisplayYOffset: 0
    FrameLayout: FullFrame
    VideoLineMap:
    [0]: 42 0
    ImageAspectRatio: { 16/9 }
    TransferCharacteristic: TransferCharacteristic_ITU709
    ImageAlignmentFactor: 8192
    ColorPrimaries: ColorPrimaries_ITU709
    CodingEquations: CodingEquations_ITU709
    ComponentWidth: 8
    HorizontalSubsampling: 2
    ColorSiting: Rec601
    BlackReferenceLevel: 16
    WhiteReferenceLevel: 235
    ColorRange: 225
    VerticalSubsampling: 1
    OffsetToFrameIndexes64: 655591
    SourceBox: { { -800/1 }, { -450/1 }, { 1600/1 }, { 900/1 } }
    EssenceBox: { { -800/1 }, { -450/1 }, { 1600/1 }, { 900/1 } }
    ValidBox: { { -800/1 }, { -450/1 }, { 1600/1 }, { 900/1 } }
    DataOffset: 393216
    FrameIndexByteOrder: 18761
    FrameSampleSize: 606208
    ImageSize: 606208
    ResolutionID: 1237
    [ SourceMob ]
    MobID: 060a2b340101010101010f00-13-000000-{ 56967d89-b182-0919-060e-2b347f7f2a80 }
    Slots: Strong Object Reference Array [3] of MobSlot
    [ TimelineMobSlot ]
    SlotID: 1
    SlotName: “”
    Segment:
    [ SourceClip ]
    Length: 2877
    SourceID: 000000000000000000000000-00-000000-{ 00000000-0000-0000-0000-000000000000 }
    SourceMobSlotID: 0
    StartTime: 0
    Origin: 0
    [ TimelineMobSlot ]
    SlotID: 2
    SlotName: “”
    Segment:
    [ Timecode ]
    DataDefinition: Timecode
    Length: 2877
    Start: 86400
    FPS: 24
    Drop: False
    Origin: 0
    kAAFTypeID_MobSlotStrongReferenceVector [2]:
    [ TimelineMobSlot ]
    SlotID: 3
    SlotName: “”
    Segment:
    [ SourceClip ]
    Length: 2877
    SourceMobSlotID: 0
    StartTime: 0
    Origin: 0
    LastModified: Jan 13, 2016 16:38:34.00 GMT
    EssenceDescription:
    [ ImportDescriptor ]
    [ NetworkLocator ]
    [ TaggedValue ]
    Value: (indirect type: aafString) “SAM FrameFlex”
    [ SourceMob ]
    MobID: 060a2b340101010101010f00-13-000000-{ 56967d8a-b5a8-0919-060e-2b347f7f2a80 }
    [ TimelineMobSlot ]
    SlotID: 1
    SlotName: “”
    Segment:
    [ SourceClip ]
    Length: 2877
    SourceMobSlotID: 3
    StartTime: 0
    Origin: 0
    CreationTime: Jan 13, 2016 16:38:34.00 GMT
    EssenceDescription:
    [ CDCIDescriptor ]
    [ NetworkLocator ]
    URLString: “file:///C%3A/Avid%20MediaFiles/MXF/1/title1452703114V056967D8A.mxf”
    Length: 1
    StoredHeight: 1080
    StoredWidth: 1920
    SampledHeight: 1080
    SampledWidth: 1920
    SampledXOffset: 0
    SampledYOffset: 0
    DisplayHeight: 1080
    DisplayWidth: 1920
    DisplayXOffset: 0
    DisplayYOffset: 0
    VideoLineMap:
    [0]: 42 0
    ComponentWidth: 8
    ColorSiting: Rec601
    ColorRange: 225
    DataOffset: 393216
    ImageSize: 606208
    ResolutionID: 1237
    [ SourceMob ]
    MobID: 060a2b340101010101010f00-13-000000-{ 56967d8b-b77c-0919-060e-2b347f7f2a80 }
    [ TimelineMobSlot ]
    SlotID: 1
    SlotName: “”
    Segment:
    [ SourceClip ]
    Length: 2877
    SourceMobSlotID: 3
    StartTime: 0
    Origin: 0
    CreationTime: Jan 13, 2016 16:38:35.00 GMT
    EssenceDescription:
    [ RGBADescriptor ]
    [ NetworkLocator ]
    URLString: “file:///C%3A/Avid%20MediaFiles/MXF/1/title1452703115V056967D8B.mxf”
    Length: 1
    StoredHeight: 1080
    StoredWidth: 1920
    SampledHeight: 1080
    SampledWidth: 1920
    SampledXOffset: 0
    SampledYOffset: 0
    DisplayHeight: 1080
    DisplayWidth: 1920
    DisplayXOffset: 0
    DisplayYOffset: 0
    VideoLineMap:
    [0]: 42 0
    PixelLayout:
    aafRGBALayout[0]: { CompAlpha, 8 } { CompNull, 0 } { CompNone, 0 } { CompNone, 0 } { CompNone, 0 } { CompNone, 0 } { CompNone, 0 } { CompNone, 0 }
    ComponentMaxRef: 235
    ComponentMinRef: 16
    OffsetToFrameIndexes: 2097383
    DataOffset: 393216
    FrameSampleSize: 2080768
    ImageSize: 2080768
    [ CompositionMob ]
    MobID: 060a2b340101010101010f00-13-000000-{ 56967db3-55ad-091a-060e-2b347f7f2a80 }
    Name: “title only.Exported.01”
    Slots: Strong Object Reference Array [11] of MobSlot
    [ TimelineMobSlot ]
    SlotID: 1
    SlotName: “”
    Segment:
    [ Timecode ]
    Length: 121
    Start: 86400
    FPS: 24
    Drop: False
    Origin: 0
    [ TimelineMobSlot ]
    SlotID: 2
    SlotName: “”
    Segment:
    [ Pulldown ]
    Length: 121
    InputSegment:
    [ Timecode ]
    Length: 126
    Start: 90000
    FPS: 25
    Drop: False
    PulldownKind: PALPD
    PulldownDirection: TapeToFilmSpeed
    PhaseFrame: 0
    ComponentAttributeList: Strong Object Reference Array [1] of TaggedValue
    [ TaggedValue ]
    Value: (indirect type: aafInt32) 25
    PhysicalTrackNumber: 3
    Origin: 0
    [ TimelineMobSlot ]
    SlotID: 3
    SlotName: “”
    Segment:
    [ Timecode ]
    Length: 121
    Start: 86400
    FPS: 24
    Drop: False
    Origin: 0
    kAAFTypeID_MobSlotStrongReferenceVector [3]:
    [ TimelineMobSlot ]
    SlotID: 4
    SlotName: “”
    Segment:
    [ Timecode ]
    Length: 121
    Start: 90000
    FPS: 25
    Drop: False
    PhysicalTrackNumber: 4
    Origin: 0
    kAAFTypeID_MobSlotStrongReferenceVector [4]:
    [ TimelineMobSlot ]
    SlotID: 5
    SlotName: “”
    Segment:
    [ Pulldown ]
    Length: 121
    InputSegment:
    [ Timecode ]
    Length: 151
    Start: 107892
    FPS: 30
    Drop: True
    PulldownKind: TwoThreePD
    PhaseFrame: 0
    [ TaggedValue ]
    Value: (indirect type: aafInt32) 5
    PhysicalTrackNumber: 5
    Origin: 0
    kAAFTypeID_MobSlotStrongReferenceVector [5]:
    [ TimelineMobSlot ]
    SlotID: 6
    SlotName: “”
    Segment:
    [ Pulldown ]
    Length: 121
    InputSegment:
    [ Timecode ]
    Length: 151
    Start: 108000
    FPS: 30
    Drop: False
    PhaseFrame: 0
    [ TaggedValue ]
    PhysicalTrackNumber: 6
    Origin: 0
    kAAFTypeID_MobSlotStrongReferenceVector [6]:
    [ TimelineMobSlot ]
    SlotID: 7
    SlotName: “”
    Segment:
    [ Pulldown ]
    Length: 121
    InputSegment:
    [ Timecode ]
    Length: 121
    Start: 108000
    FPS: 30
    Drop: False
    PulldownKind: OneToOneNTSC
    PhaseFrame: 0
    [ TaggedValue ]
    PhysicalTrackNumber: 7
    Origin: 0
    kAAFTypeID_MobSlotStrongReferenceVector [7]:
    [ TimelineMobSlot ]
    SlotID: 8
    SlotName: “”
    Segment:
    [ EdgeCode ]
    DataDefinition: Edgecode
    Length: 121
    Start: 0
    FilmKind: Ft35MM
    CodeFormat: EtEdgenum4
    Header:
    [0]: 48 48 49 0 32 32 32 32
    AvEdgeType: 1
    AvFilmType: 0
    Origin: 0
    kAAFTypeID_MobSlotStrongReferenceVector [8]:
    [ TimelineMobSlot ]
    SlotID: 9
    SlotName: “”
    Segment:
    [ Pulldown ]
    Length: 121
    InputSegment:
    [ Timecode ]
    Length: 302
    Start: 216000
    FPS: 60
    Drop: False
    PulldownKind: TwentyFourToSixtyPD
    PhaseFrame: 0
    [ TaggedValue ]
    Value: (indirect type: aafInt32) 10
    PhysicalTrackNumber: 8
    Origin: 0
    kAAFTypeID_MobSlotStrongReferenceVector [9]:
    [ TimelineMobSlot ]
    SlotID: 10
    SlotName: “”
    Segment:
    [ Sequence ]
    Length: 121
    Components: Strong Object Reference Array [1] of Component
    kAAFTypeID_ComponentStrongReferenceVector [0]:
    [ OperationGroup ]
    Length: 121
    Operation: Title_2
    InputSegments: Strong Object Reference Array [3] of Segment
    kAAFTypeID_SegmentStrongReferenceVector [0]:
    [ Sequence ]
    Length: 121
    [ ScopeReference ]
    Length: 121
    RelativeScope: 1
    RelativeSlot: 1
    Avid Scope: 1
    kAAFTypeID_SegmentStrongReferenceVector [1]:
    [ SourceClip ]
    Length: 121
    SourceID: 060a2b340101010101010f00-13-000000-{ 56967d89-b107-0919-060e-2b347f7f2a80 }
    SourceMobSlotID: 1
    StartTime: 390
    [ TaggedValue ]
    Value: (indirect type: aafString) “<?xml version=”1.0″ encoding=”UTF-8″ standalone=”no” ?> -800/1 -450/1 1600/1 900/1 -800/1 -450/1 1600/1 900/1 -800/1 -450/1 1600/1 900/1 -800/1 -450/1 1600/1 900/1″
    kAAFTypeID_SegmentStrongReferenceVector [2]:
    [ SourceClip ]
    Length: 121
    SourceMobSlotID: 2
    StartTime: 390
    [ TaggedValue ]
    Parameters: Strong Object Reference Array [10] of Parameter
    kAAFTypeID_ParameterStrongReferenceVector [0]:
    [ ConstantValue ]
    Definition: { a2e74203-8527-4f5a-aa16-4bac4607510f }
    Value: (indirect type: Rational) { 790790791/1000000000 }
    kAAFTypeID_ParameterStrongReferenceVector [1]:
    [ ConstantValue ]
    Definition: { 1fdd2907-e48c-11d3-a078-006094eb75cb }
    Value: (indirect type: AvidBagOfBits)
    [0]: 4 120 0 0 0 0 0 16 0 16 0 17 2 255 12 0
    [10]: 0 0 4 120 0 0 0 0 0 0 0 0 0 16 0 0
    [20]: 0 16 0 0 0 0 0 0 0 1 0 10 0 0 0 0
    [30]: 0 16 0 16 0 161 0 101 0 14 65 86 73 68 0 1
    [40]: 49 32 87 73 78 32 77 67 0 161 0 100 1 88 65
    kAAFTypeID_ParameterStrongReferenceVector [2]:
    [ ConstantValue ]
    Definition: { 4856d427-23ef-4437-bed2-e829977f1561 }
    Value: (indirect type: Rational) { 856856857/1000000000 }
    kAAFTypeID_ParameterStrongReferenceVector [3]:
    [ ConstantValue ]
    Definition: { 8d56812b-847e-11d5-935a-50f857c10000 }
    Value: (indirect type: Boolean) True
    kAAFTypeID_ParameterStrongReferenceVector [4]:
    [ ConstantValue ]
    Definition: { 8d56814d-847e-11d5-935a-50f857c10000 }
    Value: (indirect type: Boolean) False
    kAAFTypeID_ParameterStrongReferenceVector [5]:
    [ ConstantValue ]
    Definition: { 8d568153-847e-11d5-935a-50f857c10000 }
    kAAFTypeID_ParameterStrongReferenceVector [6]:
    [ ConstantValue ]
    Definition: { c0038672-a8cf-11d3-a05b-006094eb75cb }
    Value: (indirect type: aafUInt16) 18761
    kAAFTypeID_ParameterStrongReferenceVector [7]:
    [ ConstantValue ]
    Definition: { 1f99097e-13b8-4ae8-98fd-c3512850edff }
    Value: (indirect type: Rational) { 99099099/500000000 }
    kAAFTypeID_ParameterStrongReferenceVector [8]:
    [ ConstantValue ]
    Definition: { 93994bd6-a81d-11d3-a05b-006094eb75cb }
    [0]: 69 70 70 50 95 66 76 69 78 68 95 71 82 65 80 72
    [10]: 73 67 0
    kAAFTypeID_ParameterStrongReferenceVector [9]:
    [ ConstantValue ]
    Definition: { 760264de-f952-4525-9d3f-a4397080cb38 }
    Value: (indirect type: Rational) { 19019019/125000000 }
    ComponentAttributeList: Strong Object Reference Array [8] of TaggedValue
    [ TaggedValue ]
    [ TaggedValue ]
    [ TaggedValue ]
    [ TaggedValue ]
    Value: (indirect type: aafInt32) 152
    [ TaggedValue ]
    Value: (indirect type: aafInt32) 198
    [ TaggedValue ]
    Value: (indirect type: aafInt32) -143
    [ TaggedValue ]
    Value: (indirect type: aafInt32) -209
    [ TaggedValue ]
    Origin: 0
    kAAFTypeID_MobSlotStrongReferenceVector [a]:
    [ TimelineMobSlot ]
    SlotID: 11
    SlotName: “”
    Segment:
    [ Sequence ]
    DataDefinition: SoundMasterTrack
    Length: 121
    [ Filler ]
    Length: 121
    Origin: 0
    LastModified: Jan 13, 2016 16:38:55.00 GMT
    CreationTime: Jan 13, 2016 16:39:15.00 GMT
    UsageCode: Usage_TopLevel
    MobAttributeList: Strong Object Reference Array [7] of TaggedValue
    [ TaggedValue ]
    [ TaggedValue ]
    Value: (indirect type: aafInt32) 9
    [ TaggedValue ]
    Value: (indirect type: aafString) “HD 1080p/23.976”
    [ TaggedValue ]
    Value: (indirect type: aafString) “<?xml version=”1.0″ encoding=”UTF-8″ standalone=”no” ?> -800/1 -450/1 1600/1 900/1″
    [ TaggedValue ]
    [ TaggedValue ]
    Value: (indirect type: aafInt32) 32769
    [ TaggedValue ]
    Value: (indirect type: aafInt32) 121
    ######################## EssenceData ########################
    End of file: C:\AAF DUMPER\title only.aaf
