Activity Forums VEGAS Pro Creating a 5.1 file?
  • Creating a 5.1 file?
    Posted by Kirk Smith on June 10, 2009 at 11:22 am
    Hey, I have a quick (hopefully) question. I have 4 audio files that together make up 6 channels of audio. There are 2 stereo files that contain front left and right channels, and rear left and right channels, then there are 2 mono files which contain the center and sub channels. I’d like to know how to, in Vegas 8.1, put those together into 1 5.1 channel audio file. I’ve never really messed with any of the surround sound options in Vegas before, but I know they exist in Project Settings. How can I take those 4 files and combine them into 1 AC3 5.1 channel file?
    Thanks in advance for any help!
    Kirk Smith replied 17 years, 3 months ago 3 Members · 10 Replies
  • 10 Replies
  • John Rofrano
    June 10, 2009 at 2:06 pm
    Set your project audio for 5.1 Surround. Then drop the audio files into the project and double-click on the surround pan in the track header to bring up the big Surround Panner window and enable the speakers you want the track to play through.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Kirk Smith
    June 10, 2009 at 3:22 pm
    How do I disable or enable certain speakers? For me I can only move the little diamond around.
  • Kirk Smith
    June 10, 2009 at 3:39 pm
    Nevermind, I’m stupid. One more question though, what format do I render it into? All 4 of the files together are 108 MB but when I rendered to an AC3 file using the Doly Digital AC-3 Studio plugin with the 5.1 Surrond DVD preset, I got a 10.5 MB file that, when played in Windows Media Player, wasn’t 5.1. What do I do?
  • John Rofrano
    June 10, 2009 at 8:16 pm
    It sounds like you did everything correctly. Does Windows Media Player support Dolby Digital AC-3 5.1 Surround? (i don’t know) Is your default windows audio device set to 5.1 surround? If not, WMP might be downsampling to stereo on the fly. Try other players that support 5.1 as well.
    ~jr
  • Kirk Smith
    June 11, 2009 at 5:00 am
    Well originally it defaulted opening in Quicktime, but quicktime wouldn’t play it. It said it needed some plugin and took me to a page to download it but there was no plugin there for AC3. I thought that it was supposed to be uncompressed, why would it go from 108 MB total for all 4 original files to 10.5 MB for the AC3? That’s compression.
  • John Rofrano
    June 11, 2009 at 10:52 am
    Yes, indeed. AC-3 is highly compressed. I’m not sure why you though it would be uncompressed. WAV files are uncompressed. AC-3 is a codec, and codecs compress and decompress. 😉
    ~jr
  • Kirk Smith
    June 11, 2009 at 12:55 pm
    Do I lose sound quality? Is AC-3 a good intermediate file for use with bluray and dvd authoring? Is there a better format to use to get the 5.1 surround? Is WAV capable of 6 channels? I heard that AAC was 5.1 capable.
  • John Rofrano
    June 11, 2009 at 3:40 pm
    Yes, Dolby Digital AC-3 is exactly what you should be using for DVD and Blu-ray.
    ~jr
  • Michael Flores
    June 12, 2009 at 6:28 am
    Ive mixed in 5.1 several times in sony vegas and now the option to turn an audio track over to the audio bus. isn’t working the blue and white small box is simply not there. Not sure what happened. Any help would be great
    Thank you
  • Kirk Smith
    June 12, 2009 at 6:29 am
    Ok, thank you very much. I just wasn’t sure if the compression was going to cause a loss of quality, but if it’s what I should be using then I guess I will!
    Thanks for the help!
