Activity Forums Adobe Illustrator Creating a 3D net in Illustrator?
  • Creating a 3D net in Illustrator?
    Posted by George Tsirogiannis on September 25, 2012 at 1:11 pm
    Hey guys,
    I need to make a 3D net covering a map area.
    The net will have to look like this: https://imageshack.us/a/img89/517/kampilosi.jpg
    How can I do it in Illustrator from scratch? Is there any tool like Photoshop’s Liquify that works with vector graphics (deforming the vector points, not the pixels)?
    If not in Illustrator (though this could be very time-saving), can I create it from sratch on another application?
    Any would be appreciated! Thanks in advance! 🙂
    George Tsirogiannis replied 13 years, 12 months ago 2 Members · 2 Replies
  • Vincent Rosati
    September 26, 2012 at 12:31 am
    Generally, you would want to do this in a 3d app like Cinema 4D.
    But if you want/need to do it in Illustrator I might use Object/Blend and Object/Clipping Mask/Make.
    The attached file shows what I mean…
    4701_3dnetv10.ai.zip
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • George Tsirogiannis
    September 26, 2012 at 8:36 am
    That’s great, thank you very much for the detailed help! 😀
