Activity › Forums › VEGAS Pro › Creates scenes with multiple shots
  • Creates scenes with multiple shots
    Posted by Simon Andersson on April 30, 2013 at 7:17 pm
    This might be a weird question, and it probably won’t work, but I’m heading into quite a big project in Sony Vegas Pro 11, and I might as well check to maybe make it easier for myself.
    I’m wondering if there is a way to save a template that contains multiple videos and then switch between them all at once?
    Let me explain. I am using multiple video files at once, and I have set up different places and sizes for all of them with the Event Pan/Crop function. Now, since I am going to be cutting between different set ups all the time, i.e sometimes one of the tracks are going to be the focus and therefore bigger, and sometimes another one needs to be bigger and make the rest smaller accordingly.
    So I’m just wondering if there is a way to not need to change the Pan/Crop preset for all 4 to 5 tracks every single time i want to change it, and maybe if there is a way to save a preset for the whole thing. It’s very similar to how you can save scenes in XSplit, if anyone knows how that works.
    I know it’s a strange and very specific question, and as I mentioned, I doubt there is a way, but it would help me a lot and save me a lot of time if it did.
    John Rofrano replied 13 years, 4 months ago 3 Members · 4 Replies
  • Stephen Mann
    May 1, 2013 at 4:27 am
    I don’t follow your question, but I’ll venture a guess. You can save any FX setup with a custom name that you can reuse in any other Vegas project. So if I use event Pan Crop to size a video event as a PIP, then I could size and position it and save it as “PIP Upper-Right”. Then on any video event in this or another project, you just open the Pan Crop window and select “PIP Upper-Right” preset from the dropdown.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • John Rofrano
    May 4, 2013 at 10:57 am
    [Simon Andersson] “So I’m just wondering if there is a way to not need to change the Pan/Crop preset for all 4 to 5 tracks every single time i want to change it, and maybe if there is a way to save a preset for the whole thing. It’s very similar to how you can save scenes in XSplit, if anyone knows how that works.”
    Use Track Motion instead of Pan/Crop. Then you can simply move the media to the track that you want and it will display in the correct window because the entire track will be repositioned.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Simon Andersson
    May 4, 2013 at 1:42 pm
    Oh, I didn’t think of that! Thanks! That will speed things up.
  • John Rofrano
    May 4, 2013 at 3:53 pm
    You’re welcome. Let us know how it works out. Maybe post a sample video of your final product.
    ~jr
