Activity Forums Adobe After Effects Expressions createPath and toWorld?
  • createPath and toWorld?
    Posted by Santi Agustí on June 29, 2019 at 5:11 pm
    Hi!
    I’m trying to create a shape path which follows a mask path from another layer.
    All ok if doing the simplest
    thisComp.layer(“Black Solid 1”).mask(“Mask 1”).maskPath
    But if the Black Solid 1 is animated, or rotated, repositioned, parented, etc the shape path is not following these transformation info
    Do you know if there is a way to make a toComp to the maskPath in order to get the asbsolute values, so we always have the same shape Path (visually) as the maskPath no matter the Black Solid 1 transforms? (and even more, keeping the maskPath animation vertex keyframe data too)
    I tried to redraw the shape using the createPath method
    N = thisComp.layer("Black Solid 1");
    maske=N.mask("Mask 1").maskPath;
    points=maske.points();
    inTangents = maske.inTangents();
    outTangents = maske.outTangents();
    isClosed = maske.isClosed();
    createPath(points, inTangents, outTangents, isClosed)
    is that possible to use something like N.toWorld etc etc to make it work?
    Do you think is that way is possible somehow?
    thanks!
    Santi Agustí replied 7 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 29, 2019 at 7:46 pm
    Play around with this:
    points2 = [];
    for (i = 0; i < points.length; i++){
    points2.push(fromComp(N.toComp(points[i])));
    createPath(points2, inTangents, outTangents, isClosed)
    Dan
  • Santi Agustí
    June 29, 2019 at 8:24 pm
    thank you!!!
    this is gold!!
