Activity Forums Boris FX created timecode in RED stops before the end
  • created timecode in RED stops before the end
    Posted by Macmauro on November 22, 2005 at 3:51 pm
    Hi, i use boris red upgraded at 3.04 hosted by media 100 lx 8.2.2 Qtime 6.4 and macos 10.3.9 on g4 dual 1,25, 2 gb ram, graphic card ati radeon 9600 pro mac e pci edition 256 mb,
    I created a videclip of 31 minuted, two graphic tracks (at quality of 240 kb on 300kb for video)
    the first was of still images with alpha channel, in the 2th i generated timecode
    (generator- timecode- pal- starting at 00000, text red color and emboss 60% softness)
    I rendered all, the rendering lasts 15 hours and at the end the first track was fine rendered
    but the one with timecode was ok until 10.55.09 frame, there the timecode stopped and stayed at 10.55.09 until the end of the video.
    What was wrong? retry is hard, 15 hours, so i would understand if i made some wrong operation before.
    Any suggestion?
    maurizio
    Maurizio
    Macmauro replied 20 years, 10 months ago 2 Members · 2 Replies
  • Stephen L. noe
    November 23, 2005 at 8:56 pm
    My first thought on this is to contact Boris support. They may be able to duplicate your issue. 15 hours of render is a long time and I’ve not seen this TC issue.
    anyone else?
  • Macmauro
    November 23, 2005 at 11:54 pm
    to insert timecode in boris effect:
    face- text- generator- timecode
    you can edit the timecode numbers as you do with any kind of text (color character emboss….)
    a long time to have answer from boris support
    and creativecow is a big invention
    maurizio
