Activity Forums Adobe After Effects Created a 24p project in AE, need to export for broadcast – Now what do I do?
  • Created a 24p project in AE, need to export for broadcast – Now what do I do?
    Posted by Joshua Clarke on March 12, 2008 at 5:35 am
    Hello,
    So I’m working on a 30-second spot that will be broadcast on television. I shot my footage in 24p and created an AE project with a 23.976 framerate. To get it to the post house to transfer and dub, I’ll need an uncompressed AVI or QT file. I am not sure what the proper framerate should be, and whether I should change it in my Comp Settings, Render Settings, or Output Module.
    Do I need to get the framerate to 29.97? Can I keep it at 23.976? Did I completely screw myself by doing things this way?
    Any assistance will be greatly appreciated.
    Joseph Springer replied 18 years, 6 months ago 4 Members · 4 Replies
  • Steve Roberts
    March 12, 2008 at 11:48 am
    My gut says 29.97: render the 23.976 comp with pulldown (any cadence).
    In general, you should ask these questions of the post house or the broadcaster — don’t trust us. Who knows? Maybe they have a spiffy new way of adding pulldown in the transfer.
  • Matt Doe
    March 12, 2008 at 1:07 pm
    I work at a post house in Washington DC, we deal with these type of “outputs” all the time. Most of the outputs are done through our Final Cut system through a Kona 2 card. If you were to send a 23.98 QT, we would simply make a 23.98 sequence and let the Kona handle the pulldown and I would imagine any post house in your area would most likely handle the output the same way.
  • Joshua Clarke
    March 12, 2008 at 2:38 pm
    Matt, that’s fantastic information. Thank you very much.
  • Joseph Springer
    March 12, 2008 at 3:31 pm
    In general if you shot it in 24p you also could have shot in 30p, if the footage is for television I would shoot in that format from the get-go going forward..
    Regards,
    Joe Springer
    Certified Adobe After Effects Training and Premiere Training Instructor
