Activity Forums VEGAS Pro Create video with varying framerates
  • Create video with varying framerates
    Posted by Johnny Chevy on July 22, 2023 at 12:23 am
    My movie is 23 fps, but has a scene in it that’s supposed to be 12 fps. I rendered the scene first in 12 fps and put it in the project, than I rendered the project in 23 fps, but the 12 fps scene doesn’t look good.
    Brie Clayton replied 3 years, 2 months ago 3 Members · 3 Replies
  • Aivis Zons
    July 22, 2023 at 3:09 am
    Could it be that Smart Resample is enabled on the project? Project Properties -> Resample mode, select Disable resample. Or alternatively, you could disable it only for the one clip. Right click on the clip -> Switches -> Disable Resample.
    If that didn’t help then maybe try changing Field order in project/render settings – set it to None (progressive scan). This setting can also be changed only on the clip – right click -> Properties -> Media and there should be a Field order dropdown.
  • Johnny Chevy
    July 22, 2023 at 5:51 am
    Wow. Perfect. What would I do without you?
  • Brie Clayton
    July 23, 2023 at 1:00 am
    Thanks for your solve, Aivis!
