Activity Forums Adobe After Effects Create video sequence with text layers same length as videos?
  • Create video sequence with text layers same length as videos?
    Posted by Gabe Hartman on October 22, 2015 at 5:20 am
    Alright so I’m trying to figure out a simpler way of doing this, which I imagine there’s got to be.
    So pretty much I have a large amount of videos that I need to overlay text over, each text is different (not all videos are the same length)
    example of what im working with: https://i.imgur.com/hrMhtWT.png
    So I wanted to know if there’s like a possible way of like taking this sequence and converting these to a text layer or a way of sequencing them with text layers when putting it into a composition or something?
    (btw the text needs to go the length of each vid incase you didn’t get what I was saying)
    View post on imgur.com
    Gabe Hartman replied 10 years, 10 months ago 2 Members · 2 Replies
  • John Cuevas
    October 22, 2015 at 11:33 am
    You could drag each video layer and drag it on to the new comp button, that creates a new comp the length of you video layer. Do that for each
    video layer and add text to each comp. Then take each of these completed comps and drag them on to the create comp button and if you selected them in the order you want them be in your video, choose single comp in the dialogue box and they will be correctly sequenced. Otherwise, just order them from top to bottom, use the animation assistant sequence layers.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Gabe Hartman
    October 22, 2015 at 6:07 pm
    Thats seems like more work than just making individual text layers the same size of each video imo.
    I have to do this for like 300+ videos.
