Activity Forums VEGAS Pro Create Vegas Pro 13 Plugin/Extension
  • Create Vegas Pro 13 Plugin/Extension
    Posted by Thomas Ames on September 12, 2016 at 3:07 pm
    I’ve recently learned the basics of FFmpeg for trimming down a large file to a smaller file containing certain footage copied from the original file.
    I’ve seen there are plugins/extensions available for FFmpeg in Vegas Pro 13, but they include many options and settings which I don’t need (and probably don’t understand).
    The line I’ve been using is:
    ffmpeg -ss [START TIME] -i [INPUT].mp4 -map 0 -c copy -t [DURATION] [OUTPUT].mp4
    I imagine that all I’d need is:
    1) GET selected range in Vegas
    2) Take start and end time from that selected range
    3) calculate duration based on end-start
    4) video being selected in range set as [INPUT] file
    5) user input for [OUTPUT] file
    6) Run that line through a CMD window.
    It really wouldn’t take long at all and could be done with a simple batch file, but I would like to be able to do it from within Vegas; I just can’t find much useful information on creating a plugin/extension nor getting Vegas related syntax.
    i.e.: startTime = timeline.selection.start
    Could anyone point me in the right direction for learning code for Vegas?
    Thanks for your time.
    -Tom
    John Rofrano replied 10 years ago 3 Members · 8 Replies
  • 8 Replies
  • John Rofrano
    September 12, 2016 at 4:14 pm
    [Thomas Ames] “Could anyone point me in the right direction for learning code for Vegas?”
    You would need access to the Script Development SDK which is no longer downloadable that I can see. I tried to download it from the Sony site but it redirects me to the main page of MAGIX site with no downloadable link in sight. 🙁
    Maybe someone here has an old bookmark that still works. I do not.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Jorma Nippala
    September 12, 2016 at 5:58 pm
    You might try to google “vegas + download development kits”.
    You should get a cached version of Downloads still.
  • Jorma Nippala
    September 12, 2016 at 6:00 pm
    Another option there
    https://download.sonymediasoftware.com/dev/
    (Used to be nice to be able to edit posts here.)
  • Thomas Ames
    September 12, 2016 at 6:12 pm
    Hey Jorma, thanks for that!
    Googling for “vegas pro 13 + download development kits” doesn’t yield anything I appear to be able to use.
    https://download.sonymediasoftware.com/dev/ looks like I should be able to use it, but I don’t entirely understand it.
    The second from last option “vegasscriptsdk.zip” looks like the correct choice for me, but would you be able to say if there’s a better option, based on what I’m trying to do?
    Thank you!
    -Tom
  • Jorma Nippala
    September 12, 2016 at 6:28 pm
    My cached Downloads page gives these explanations
    Video Plug-In Development Kit (OFX) updated on Apr. 3, 2013 (409 MB)
    Vegas Pro Script Developers Kit – Versions 10-13 updated on Dec. 22, 2010 (135 MB)
    JR or others will probably advise further.
  • John Rofrano
    September 12, 2016 at 10:10 pm
    [Thomas Ames] “The second from last option “vegasscriptsdk.zip” looks like the correct choice for me, but would you be able to say if there’s a better option, based on what I’m trying to do?”
    That’s the one you need. The Script SDK.
    ~jr
  • Thomas Ames
    September 12, 2016 at 10:44 pm
    Thanks for that. Any place I can check out the proper Vegas related syntax?
  • John Rofrano
    September 12, 2016 at 10:57 pm
    [Thomas Ames] “Any place I can check out the proper Vegas related syntax?”
    It’s all in the ZIP file. What it contains is API documentation.
    ~jr
