Activity › Forums › Adobe After Effects › Create this simple effect
Posted by Hanna Dean on May 9, 2016 at 10:28 pmi want to add this black hole on a face with the sharp corners and now doing something add a terminator face or metal behind that black area and the sharp area corners should look like the skin is wripped up.
kindly help with basic tutorial on this.
for exampleSoham Jani replied 10 years, 4 months ago 6 Members · 10 Replies -
Bob Cole
May 10, 2016 at 1:44 am[Dave LaRonde] “That’s not an effect — that’s hours of painstaking face-painting.”
Except maybe for the red eyeball?
Isaac Someah-kwaw
May 10, 2016 at 2:14 amFrom the looks of it, this would be a job better suited for Photoshop than After Effects, unless you intend to animate the face somehow. It shouldn’t be to terribly difficult using some masking.
I imagine you could just use the magic wand selection tool to select the black area, and then create an inverted mask that turns it into transparency. Then place another metal image similar in color and texture to the other metal face parts in a layer below the hole layer. Then, either mask or delete any extra metal area that would hang out from under the hole layer’s outer edges. That would get you part of the way there. And then you can do some color correction and clone stamp/healing brush work to make the hole layer better mesh with the skin tone and texture.
After you finish that, then you could import the final product into after effects and do anything else you had in mind.
Hanna Dean
May 10, 2016 at 6:13 ami will post a video here asap of what i know then kindly help me on how to fix it.
it is possible and am seeking help buddy thats all i ask
Tudor “ted” jelescu
May 10, 2016 at 7:31 amDepending on the shot, if the face moves much, if it turns or not, there are several ways of approaching this.
If the face is not turning (or turning just a bit), you can paint the patch in PSD (create a patch with edges and terminator head under) and then use Mocha to track and comp that patch on the face. A bit of distortion may be necessary using Mesh Warp.
For a 3d move, where the face turns, you need a 3d track and a 3d patch. First stabilize the head, to have it always in the same spot in the frame (track 1). Then isolate (crop) the head and do a 3d camera track (Track 2) and a camera solve. Use FreeForm Pro to create the 3d patch and position in 3D space and render that on the head. Then comp back the head in the shot reversing the Track 1 stabilization.Tudor “Ted” Jelescu
Senior VFX Artist -
Kalleheikki Kannisto
May 10, 2016 at 9:09 amFor Andrew Kramer’s approach, see this:
https://www.youtube.com/watch?v=vIEdhlS-zYA
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Hanna Dean
May 10, 2016 at 4:23 pmi wanted a tutorial like this
https://www.youtube.com/watch?v=82xHrOW9a6A
i just found that now.if a kid can do this am sure you guys spent many years in after effects u must know a simple apprache to what i wanted to do
Hanna Dean
May 10, 2016 at 4:48 pm -
Bob Cole
May 10, 2016 at 5:36 pmHanna, thank you for sharing the YouTube video.
Good luck with your project.
Bob C
Hanna Dean
May 10, 2016 at 7:27 pmthis video gave me idiea it has not helped how ever i am trying to use andrew kramer method rather then photoshop method , using black hole background then adding an image behind it , this way u can get more details into the scene rather then static photoshop image
Soham Jani
May 11, 2016 at 1:20 pmNot sure what version of AE you’re on, but I believe the new version comes with a face tracker, so that might be of some help.
\”It\’s all around us Neo, temporary constructs of time…..\”
