Activity Forums Adobe After Effects create tech eye with trapcode
  • Michael Szalapski
    March 22, 2016 at 9:18 pm
    I’d be more inclined to try to make it in Form vs. Particular, but it’d be even better if you could do it with a 3d model of an eye.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Daniel Waldron
    March 22, 2016 at 9:35 pm
    In addition to the 3D movement on the eye and a particle system of some sort, I see a lot of animated shape layers, Plexus or Nodes 2, animated text, grids, and a healthy does of blurs or depth of field. A shot of this complexity can’t be created with a single plugin or effect.
  • Susan Lan
    March 23, 2016 at 7:25 pm
    Thanks! then I must first create a eye blinking animation, ¿do you know any tutorial about creating and animating a blink eye please? then I must import de 3d sequence into AE with trapcode form?
