Activity Forums Apple Final Cut Pro Legacy Create Subtitles for TV-Show
  • Create Subtitles for TV-Show
    Posted by Veronika Zaplata on July 2, 2012 at 7:28 am
    Hi everyone,
    I am working for a dubbing company in Mauritius. Our client recently asked if there is a possibility to do also subtiteling. Is there anyone who could advise me. I have a exel or word document with the translation and the TC’s. What software can I use to import this into FC or Avid. I need to deliver a .mov or .avi to my client.
    Thanks for your help!!
    Vero
    Simeon Pines replied 14 years, 1 month ago 5 Members · 4 Replies
  • Mark Suszko
    July 2, 2012 at 4:16 pm
    There’s a COW forum just for captioning: your best advice will come from there.
    https://forums.creativecow.net/closedcaptioning
  • Andreas Kiel
    July 3, 2012 at 9:22 am
    Vero,
    For Avid it should be easy to convert your Word doc to an Avid compatible text format.
    It’s format looks like below:
    TC In space char TC Out return char Subtitle double-return.
    01:00:00:00 01:00:03:12
    Just some made up subtitle text 01
    01:00:04:08 01:00:09:16
    Just some made up subtitle text 02
    01:00:10:13 01:00:15:21
    Just some made up subtitle text 03
    Once you have done that you need to add a header at the start:
    @ Header
    You may experiment with the numbers.
    You also need to add a "closing" tag at the end of the document:
    So finally your Word document will look somehow like below:
    @ Header
    In Word now save as plain text and import into Avid.
    -Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Jim Reed
    July 4, 2012 at 12:38 pm
    I use Sublime by Supramotion. https://www.supramotion.de/software/changelog
    After you have developed your movie, send it out as an .mov. It will drop into Sublime. You can save the Word document as a Rich Text file and it will drop into Sublime. Then it’s just a matter of synching the two together. This does take time however, but the results are excellent.
  • Simeon Pines
    July 26, 2012 at 7:56 pm
    I’ve just been looking at the demo version of the Sublime program. Can anyone tell me how to get white subtitles on a solid black background (a bar the same length of the text)? Would that be done in FCPX?
