Activity Forums Apple Final Cut Pro Legacy Create subclips using batch list
  • Create subclips using batch list
    Posted by Josh Haggard on December 14, 2010 at 3:54 am
    I am new to subclips and media management in general.
    I captured a complete reel.
    I have an xls of subclips, with media start and media end points. (used the log template here: https://www.larryjordan.biz/goodies/tools.html )
    When I import this ‘batch list’ i get a number of ‘unconnected media’ clips in the bin, with the ‘media start’ and ‘media end’ points in the right place.
    How do I use these unconnected clips to get just the chunks i want from the complete reel?
    If I try and ‘reconnect media’ it gives me an error. If i click ‘continue’ anyway, the clip just turns into a duplicate of the full reel.
    Can anyone help me?
    Josh
    Kent Hayward replied 15 years, 7 months ago 3 Members · 3 Replies
  • Shane Ross
    December 14, 2010 at 6:52 am
  • Kent Hayward
    January 26, 2011 at 7:54 pm
    I am having a similar problem connecting an Excel generated batch list to a pre-digitized reel of media. I’ve done it a million times to do a batch capture, but am not able to “reconnect media” to this file.
    The 30 minute media file (or reel) plays fine in fpc and I’ve replicated all of the column headings in my batch list to match it.
    Here’s my process:
    I open a new bin, import a batch list (my tab delimited excel file), all 300 of my variously named clips appear in the bin. Then I select all of the clips and “reconnect media”, I navigate to the media file that the dupe house gave me, deselect the “matched name and reel only” box, and click “connect”. I then get the “some attributes don’t match: Media Start and End” message, and click “continue”. One clip of 300 seems to connect and I click the “connect” button (instead of the “cancel” button). The result is that nothing has connected.
    Any ideas? It seems like a pretty simple thing, but the addition of the tapeless workflow is messing with me. I’ve done similar operations so many times I’m having a hard time figuring out why this won’t work.
    Thanks for your help!
    Kent
  • Kent Hayward
    January 27, 2011 at 12:45 am
    …Oh, and I’ve also tried Fcpreconnect, which sees the connection between my batch list and my source reel, but the list it generated (xml) gave me “a XML Translation was aborted due to a critical error” message when I tried to import in into FCP.
    Kent
