Activity › Forums › Adobe After Effects › Create stripes procedurally
Posted by Eric Chard on July 16, 2013 at 3:01 amWhat would be an approach to generate parallel stripes procedurally in AECC?
They could either be hard-edged, or soft-edged.
“Putting the HARM in ‘harmonica’ since 2005.”
++++++++++++++++Eric Chard replied 13 years, 1 month ago 3 Members · 6 Replies -
Eric Chard
July 16, 2013 at 4:48 amThe answer is to use the CHECKERBOARD effect in Width & Height Sliders mode.
Doyle Lewis
July 16, 2013 at 6:07 pmCreate a black and white solid (or whatever 2 colors you want your stripes to be). Duplicate both layers several times (the more times the thinner the stripes). duplicate one layer a last time so that there is an odd number. now sort these layers alternating from top to bottom. E.G.; white black white black white black white. Notice that the layers start and end with the same color. now parent layer one to layer two. then parent layer 2 to layer 3, and layer 3 to layer 4 and so on until all layers are parented to the layer below them except for the last layer which is parented to none. then make sure all layers are highlighted and hit p for position. With all layers highlighted move the y position (for horizontal stripes, x value for vertical stripes) to a higher or lower value until all stripes are of even width. That is the simplest way I can think to do it.
Doyle Lewis, Assistant Videographer
thinkck.com
Eric Chard
July 16, 2013 at 6:20 pmDoyle, we must have crossposted- the CHECKERBOARD effect I posted is far simpler.
It’s worth noting that for this specific application, to work with PIXEL DISPLACEMENT the checkerboarded layer needs to be pre-comped, because PIXEL DISPLACEMENT looks at the original layer, without any effects, to do its thing: IOW, it only sees a solid, not a checkerboard. Once it’s properly pre-comped, this is not a problem.
Thanks.
Doyle Lewis
July 16, 2013 at 7:20 pmhaha yeah I did cross post. I leave the cow up on my comp and I forgot to hit refresh before I answered this post so didn’t see that it was already answered. I liked your checkerboard point though. I tried it immediately and I see your point with precomping.
thinkck.com
Frank Feijen
July 17, 2013 at 7:01 amCheckerboard is a great way to go. But if you would want more control on the shape of the lines, you could achieve the same with a shape layer. Draw 1 line, adjust to taste and add a repeater. To feather: add blur.
Eric Chard
July 17, 2013 at 7:13 amThat’s a very good point: for instance, to make repeating, oh, sine-ish waves, or any arbitrary curve, Shape Layers would be the way to go.
A month ago, I hadn’t even heard of them! Oy. #redface
