Activity Forums Adobe After Effects Create sphere with image mapped inside…
  • Create sphere with image mapped inside…
    Posted by John Isaacks on June 22, 2009 at 3:56 pm
    I have a bunch of 3D layers with a camera moving around looking at them. I want them to appear to be in outer space. I have an image of stars, currently I have 6 copies of this image creating a box around everything else so no matter what angle you are looking at there is always stars in the background which looks really cool as the camera moves around. However I think it would be much better if I could warp the image into a sphere around everything instead of a box…does this make sense?
    Is there a way?
    Thanks!!!
    Cassie Delapp replied 12 years, 10 months ago 5 Members · 5 Replies
  • Zach Gunter
    June 22, 2009 at 3:58 pm
    look up “horizon” plug-in
    Frozensmokeprod@aol.com
  • John Isaacks
    June 22, 2009 at 4:15 pm
    Alright, I think I will just use the boxes I set up… with the stars at least it looks decent enough. That horizon plug-in looks cool, but I think I’ll hold off on purchasing it for now.
    Thanks.
  • Michael Szalapski
    June 22, 2009 at 4:55 pm
    Horizon is great.
    If you have Particular, there is a preset you can look at that puts a bunch of stars way off in the distance and it works with AE’s camera too.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • David Bogie
    June 22, 2009 at 9:42 pm
    Add some very cool perspective to your project easily. Create a couple of additional layers of stars with much fewer stars and maybe a couple of them slightly larger, and place this layer half the z distance from the existing box’s surfaces. Now as you move the camera, there will be a foreground layer of stars that moves against the background.
    another thing that adds incredible drama to the standard ho-hum starfield is a couple of images of galaxy clusters.
    bogiesan
  • Cassie Delapp
    November 11, 2013 at 7:01 pm
    Did you ever find a solution to this problem?
