Activity Forums Maxon Cinema 4D create small bubble splashes on the surface
  • create small bubble splashes on the surface
    Posted by Alexander Rohi-bilverdy on January 13, 2020 at 1:19 pm
    Hello
    I have a big pot where i will have it filled up with fluids.
    Below i have a small fire going on, which is acting like boiling the soup/fluids inside the pot.
    Now my question, how do i create the effect of small bubble splashes on the surface of the soup?? Hope this makes sense…
    Looking forward to your answers
    Br Hamid
    John Williams replied 6 years, 8 months ago 3 Members · 3 Replies
  • Marco Nutella
    January 14, 2020 at 10:39 am
    Hi, if you have x-particles, try to emit some from the bottom of the fluid, and then when reaching the top surface (via fallof), try to delete them with some tiny spawns that drive little splines, and give the splines some material, I think it could give the sense of popping bubbles.
    Marc
  • Alexander Rohi-bilverdy
    January 14, 2020 at 1:33 pm
    Don’t have xparticles
  • John Williams
    January 20, 2020 at 10:35 am
    Hi there, you could simply try having sphere’s from an emitter rising up with a ‘Collision deformer’ on the surface. That will create dome deformations on the surface which then disappear when they go above the surface. If you then want more control on the secondary animation you could add a ‘Jiggle deformer’ so the surface wobbles a little after each bubble breaks through.
    Hope that helps;)
    John Williams
    Soho Editors
