Activity Forums Adobe After Effects Create shape from center (center point or anchor point is where I start dragging my cursor)
  • Create shape from center (center point or anchor point is where I start dragging my cursor)
    Posted by Sebastian Lee on December 18, 2012 at 3:14 pm
    Just like in Gimp, a photo editing software, you have the option to create a shape from center, which means at where I start dragging my cursor to draw that shape, that will be the center point / anchor point of my shape. I am used to that, that’s my nature. I loathe to create a shape, or can be mask too from its corner. I prefer drawing from center. So is there a preference setting for this? Thanks guy!
    Stephen Smith replied 13 years, 8 months ago 4 Members · 3 Replies
  • John Cuevas
    December 18, 2012 at 4:33 pm
    On the PC you would hold down “shift+cntl” when creating your shape and will scale from the center. That will not put the anchor point in the center though. You can use the Pan Behind/Re-position Anchor Point Tool(Y) to do that though and if you hold down “cntl” you can get the anchor point to snap to the center of your shape.
    Starting with Tutorial 17, Andrew Davis covers pretty much everything you could ever want to know about shape layers. After Effects basics tutorials by Andrew Devis
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Todd Kopriva
    December 18, 2012 at 4:34 pm
    This information is in the After EffectsHelp section on drawing shapes:
    https://helpx.adobe.com/after-effects/using/creating-shapes-masks.html#create_a_shape_or_mask_by_dragging_with_shape_tools
    After Effects team blog
  • Stephen Smith
    December 18, 2012 at 4:48 pm
    On a mac you hold down the Command key which is sometimes called the Apple or Flower key.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
