Activity › Forums › Boris FX Particle Illusion › create pre set
create pre set
Posted by Fox1339 on September 12, 2007 at 12:37 amhow can I add this particle into the cs3 pre set pannel? Thanks fox.
Accountclosed replied 19 years ago 3 Members · 2 Replies -
Aharon Rabinowitz
September 12, 2007 at 4:16 amAre you asking how to add particleIllusion presets into AE CS3’s presets?
It is not possible. Presets are for AE properties only. pIllusion is a stand alone program with no properties in AE.
Accountclosed
September 12, 2007 at 7:05 amIf it is a moving sequence, Alan knows what he’s talking about, obviously.
That said, if you wish to use a still frame of a particle created in PI (i.e. as a brush or object in a PhotoShop and other such apps that allow you to do so), then you can do this:
— Export the project or frames range of your project in PI that holds the best example of you want as a .PNG sequence with alpha channel and black removed into an empty folder.
Then pick the frame you like best and import into PS, etc.
