Activity Forums Maxon Cinema 4D create polygons from pointcloud
  • create polygons from pointcloud
    Posted by Ronny Traufeller on January 25, 2011 at 3:49 pm
    hey,
    i got a nice matchmove and i want to rebuild some of the geometry.
    the pointcloud looks usefull to build a mesh that fits very well.
    i tried to use the “create polygon” tool to draw alog points on the same plane, checked points in the snaping settings and so far. but it wont let me create a snaping polygon. i think the points are null objects
    wich are not able to snap like i need it.
    this would be the workflow i am looking for, any way to convert these points/objects to polygons.
    for cubic shapes i usually put 4 point in a tracer combined with loft nurbs, but this is not that simple, i got a lot points arround the surface wich i already axtracted, but i dont want to bring them in order to use the tracer object.
    i googled some threats about this issue but i cant find a good solution.
    so has anybody ideas or links that could maybe help out here?
    thanks rOnny
    Adam Trachtenberg replied 15 years, 7 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    January 25, 2011 at 5:49 pm
    You should turn on axis snapping if you’re trying to snap to nulls. You might first need to select all the nulls and run the Axis Center function.
  • Ronny Traufeller
    January 26, 2011 at 3:38 pm
    oh jeah that is working.
    it would be nice to have a highlight function or something that shows wich
    pionts are actually affected. like the transfer function, where you can see a white line.
    is there anything like that?
    because i got a lot points in very small area and its never picking the right one 🙂
    thanks!
  • Ronny Traufeller
    January 26, 2011 at 3:40 pm
    *sorry for doubleposting*
    thanks!
    zaid-ysap.de
  • Adam Trachtenberg
    January 26, 2011 at 7:32 pm
    Unfortunately there’s no highlighting for this.
