Activity › Forums › Apple Final Cut Pro Legacy › Create offline list not using Final Cut
  • Shane Ross
    December 3, 2009 at 6:28 pm
  • Kevin Monahan
    December 3, 2009 at 6:33 pm
    Of course: Numbers or Excel spreadsheets work fine. Just keep the order of the columns the same as FCP.
    Clip Name Media Start Meda End
    etc.
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Jason Brown
    December 8, 2009 at 8:18 pm
    Alright…I’ve got it working (kinda)
    I import the clips in…time code is coming in correct on my offline clips…
    Issue is…I really wanted to (and neglected to mention) that I want all these clips to be subclips of ONE media file I already have…they aren’t coming off tape…so when I reconnect one of the offline files…it really needs to be a subclip of the source file. Is there a way to label the offline clip as a subclip?
    -Jason
  • Shane Ross
    December 8, 2009 at 8:23 pm
    Oh…well you needed to say that.
    No, there is no way internally with FCP that you can do that. There is, however, third party software that might be able to do just that. Reconnect smaller clips to one large already captured file, FCP RECONNECT:
    https://www.videotoolshed.com/?page=products&pID=41
    Shane
  • Jason Brown
    December 8, 2009 at 8:34 pm
    Great!
    Sorry to not mention that at the beginning…forgot that I wouldn’t be batch digitizing them….
    Do you use FCP reconnect to do this? I watched the tutorial…seems maybe a LITTLE over my head…I may be able to figure it out, but before I got it I wanted to make sure it definitely could.
    -Jason
  • Shane Ross
    December 8, 2009 at 8:38 pm
    I have used FCP reconnect to reconnect several clips to one big master clip that I had to recapture from scratch, because the person who did the initial capture didn’t allow for Pre roll. So when the media went offline (drive died) I couldn’t recapture that tape as logged. So I had to recapture it again, and because it had different IN and OUT points, and DURATION, then FCP couldn’t see it. But FCP reconnect worked wonders.
    If this is a little over your head, then I suggest sticking to doing things manually. Take their IN and OUT points, load the clip into the viewer, use those (manually typing them) to make subclips that you then name how they named.
    FCP reconnect will save you tons of time.
    Shane
  • Jason Brown
    December 10, 2009 at 2:01 pm
    Shane,
    I got brave…and downloaded the program. I’ve gotten it to work! Thanks so much…this is a huge timesaver.
    Quick question on how to make it work better…when I export a batch list from FCP to select the clips to link it up to…it exports EVERYTHING from my bin. Is there a way to export a batch list of selected items? I just went into text editor and deleted the other stuff I didn’t want to mess with…
    -Jason
  • Shane Ross
    December 10, 2009 at 9:52 pm
    The author, Bouke, lingers here. I’ll let him answer that one.
    Shane
  • Bouke Vahl
    December 11, 2009 at 11:38 am
    well, how about just creating a new bin, put the stuff you want to export there and export?
    Or am i missing the point?
    Bouke
    smart tools for video pro’s
  • Jason Brown
    December 11, 2009 at 1:26 pm
    The way my experience is (FCP7) is when I export -> Batch List. It exports EVERY clip in my project REGARDLESS of what I have selected.
    -Jason
