Activity › Forums › Adobe After Effects › Create New Sequence from Photoshop Layer Comp
  • Create New Sequence from Photoshop Layer Comp
    Posted by Peter Jones on November 29, 2017 at 12:12 pm
    Hi CC,
    Is there a script that will automatically create New Sequences from Layer Comps? My graphic designer has generated hundreds of Layer Comps in Photoshop.
    Or is it best to export hundreds of new Photoshop files and then import as comp?
    Let me know
    thanks – Pete
    senior editor
    Ian Watkins replied 8 years, 10 months ago 2 Members · 1 Reply
  • Ian Watkins
    November 29, 2017 at 3:42 pm
    Not sure about scripts, but Photoshop folders will import as comps in AE. So if you put all those files from the comps into folders in PS, you should get what you want automatically.
    Hope that helps!
    Ian
