Activity Forums Adobe After Effects Create new empty file using same settings as another one
  • Create new empty file using same settings as another one
    Posted by Nicolas Guionnet on March 28, 2024 at 7:51 pm
    Hi !
    Sorry if this looks basic to most of you.
    I haven’t used AE for 2 years … I need to create a new file using the same settings as my previously used file ( render settings , etc … ).
    I just tried to copy my last file and empty it.
    I saw that emptying the project tab, it was possible to really delete all the assets ( not only in my AE file … but for real … ).
    So I just decided to ask for some advice before I do something catastrophic …
    Thanks for any advice,
    Nicolas Guionnet replied 2 years, 5 months ago 2 Members · 2 Replies
  • Chris Voelz
    March 29, 2024 at 3:48 pm
    Render settings and output modules aren’t associated with projects but rather your version of After Effects. You can find those settings buried inside preference files on your computer, AppData\Roaming\Adobe\After Effects\xx.x folder. It is possible to copy those between preference files as long as you didn’t delete them. Whenever you install a new version of After Effects it asks if you want to copy those settings into the new version. If you don’t have those previous files saved then you will need to set everything up again. You can do that when you send something to the Render Queue or go to Edit > Templates > Render Settings/Output Module.
    Copying an After Effects file will only maintain composition settings and project settings associated with audio, expression engine, 3d, time, and color.
  • Nicolas Guionnet
    March 29, 2024 at 5:52 pm
    Thank’s Chris,
    This solves my problem, as I haven’t upgraded anything in the mean time …
    Nothing to do then.
    Have a nice day.
