Activity Forums Adobe After Effects Create moving thru flowers effect – How
  • Create moving thru flowers effect – How
    Posted by Hope Holmesby on August 10, 2015 at 12:18 am
    Hi…
    Thanks for reading this…appreciate so much
    Would you look at this video?
    Sample Video – Movie thru flowers
    How does one do this?
    I have a bunch of flowers on layers, one flower per layer, I want to have it look like this.
    What exactly do I do to animate like this?
    For example, I dont know even how to set it up…
    First you make a very large scene? my view port is 1024 x 576, so i would make the scene bigger? then pull the scene / psd layers into ae and zoom in on it all? the animate the camera thru it slowly?
    do i have to make sure the layers are nicely spaced in the top view?
    What do you think?
    Warmly,
    Hope
    __________________________________________________
    Life is here to enjoy.
    iMac 3.5 GHz Intel Core i7, 2TB;
    Mac OS 10.9,
    16 GB RAM;
    2 La Cie external HDs 1 TB each;
    After Effects CS5.5;
    Sound Track Pro 3.0.1;
    Final Cut Pro 7.0.3;
    Compressor 3.5.3
    Hope Holmesby replied 11 years ago 2 Members · 4 Replies
  • John Cuevas
    August 10, 2015 at 1:07 pm
    You pretty much nailed the technique, that’s exactly how you do it. If you google “kid stays in the picture” tutorial or 2.5d tutorial, you will find a lot of videos that go into this technique.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Hope Holmesby
    August 10, 2015 at 6:31 pm
    Hi John
    Thank you so much for your reply.
    the tutorials I found…..thanks to you, by searching
    I am using cs5.5….so a little out of date….guess the new ae has more tools for 3D.
    am working in 16.9 SD 1024x576px
    Question:
    Do you think I am doing this right?
    This is the Right view. (realizing i may need to work in top view)
    camera:
    set: Point of Interest, Position and Zoom.
    Camera layer only has keyframes: this is where 1st set of these keyframes are
    This is where the 2nd ending set of these same parameters are set. had the camera triangle, the red, that far out, in order to make sure the last image went fully out of the frame.
    I was a little worred that there are images off / out of the viewport…the white checkdered area.
    what do you think?
    I still need to add alot more pics.
    one just makes precomps for each set of images like these 6? The sample video above must have about 100 layers they are touring the camera thru?
    Any thots?
    Thanks ever so much.
    Mac OS 10.9,
    16 GB RAM;
    Compressor 3.5.3
  • John Cuevas
    August 10, 2015 at 7:30 pm
    It sounds like you are going about this the correct way. Precomping could help, but it will add cause some issues where the precomp space won’t equal the final comp space. You could work around that, but probably not worth the hassle.
    The 3D tools in the CC version really wouldn’t offer you much more than you have now for this particular project.
    ThinkCK
  • Hope Holmesby
    August 10, 2015 at 8:01 pm
    Hi John,
    Ok, thank you for the encouragement and confirmation….steep learning curve for me…lol
    and the info about cc 3D
    I will keep watching tutorials and experimenting….
    wow
    thanks again so much for your attention .
    warmly,
    Hope
    Mac OS 10.9,
    16 GB RAM;
    Compressor 3.5.3
