Activity › Forums › Adobe After Effects Expressions › Create / Modify key frames positions values with expression
Posted by Clement Dubois on November 3, 2021 at 10:06 amHi !
I am wondering if there is a way to modify the values of position keyframe with my expression.
I have a layer with a drop menu effect and a position expression :
dropMenu = effect("Dropdown Menu Control")("Menu");
if (dropMenu ==1) {
mPosition= 300;
}else if (dropMenu== 2) {
mPosition= 500
[value[0], mPosition]To be precise, I want to animate the position value, I wonder if there is a way to apply or modify the value of a keyframe if I change the dropmenu value ?
Clement Dubois replied 4 years, 10 months ago 4 Members · 6 Replies -
Dan Ebberts
November 3, 2021 at 1:49 pmYou can’t actually modify keyframes with expressions, but you might be able to simulate the result, depending on what you need to do. You can certainly use the timing of the keyframes to drive your expression animation, but it can get tricky if you also need to preserve the easing of your keyframes. You can probably do it if you just need to proportion the keyframe animation based on the value of your dropdown menu, but it depends on the details of how you have things set up.
Tomas Bumbulevičius
November 3, 2021 at 2:46 pmHey Clement, the question here is whats behind as well as ahead of your selected keyframe to be modified
As Dan mentioned – directly you won’t be able to alter it. However, if you give us a bigger picture of task, I am sure workaround can be found.
Clement Dubois
November 5, 2021 at 2:51 pmHi !
I sent you a picture of the work I try to achieve.
As you can see on the picture, by changing the drop menu value, I want to automatically change the value of the 2nd position keyframe but keep the animation and the value of the 1st position value.
And the expression I wrote don’t work 😕
Andrei Popa
November 6, 2021 at 8:33 amHi Clement. I think you need one of the following expressions, based on whether the second value of y position is greater or smaller than the first. The linear() function needs the 2nd parameter to be smaller than the 3rd.
So if the position of your second keyframe is lower than the first, use this
myListe = [195.7, 258.2, -320.7];
myPlace = myListe[dropMenu - 1];
key1 = key(1).value[1];
key2 = key(2).value[1];
yVal = linear(value[1], key1, key2, key1, key2 + myPlace);
[value[0], yVal];Otherwise, use this
yVal = linear(value[1], key2, key1, key2 + myPlace, key1);
[value[0], yVal];You need to modify these a little to fit your project.
Dan Ebberts
November 6, 2021 at 6:52 pmThere are some situations where you might need a different approach. For example, if the y position of the 1st and 2nd keyframes are the same (and maybe the y value goes above and/or below the keyframe value in between). In that case you might want to proportion the y offset, based on how far along you are between the two keyframes, like this:
myListe = [195.7, 258.2, 320.7, 445.7, 508.2, 570.7, 633.2, 695.7, 758.2, 820.7, 883.2];
t1 = key(1).time;
t2 = key(2).time;
yOffset = linear(time,t1,t2,0,myPlace)
value + [0,yOffset]
Clement Dubois
November 22, 2021 at 12:45 pmHi, thank you, Andrei and Dan for your replies.
I tried what you sent, and the second expression of Andrei work fine !
