Create Menu that becomes animated when button selected
Hi
I am using Vegas 6 and DVD Architect 4.
I want to create a menu so that when you select a certain next button that it plays an mpg that begins with the “menu” but is actually part of the mpg.
I know I am not being clear. So when you click a button on the menu it appears that the menu is starting to do things it hadn’t before.
I tried making the menu the size for ntsc widescreen, but when the mpg is played it is smaller than the menu size.
I want this to be as seemless as possible.
I hope someone can help, and thanks!!
Dan
