Create Mask based on color (much like Photoshop Magic Wand)
Is there a way to create a mask based on a particular color. It would be something like the Magic Wand tool in Photoshop or the color key plugin except that it would not key that color out but mask it, so that I could eliminate everything but that color. Any ideas?
What I want to do with it:
I pulled frames of NASA World Wind, then creating a movie from the stills, giving me a dynamic satellite flyover starting with a closer view of the middle east which is then enlarging to a view of the whole Mediterranean. Now I want to animate the spread of an idea from the middle east to Europe by a color layer expanding.
My problem: The ocean should not be affected by the color layer, but since the sequence is a dynamic zoom (and turn) of the map, the outlines of the ocean change in every frame. Changing the mask shape every frame would be an incredible pain. If on the other hand I could single out an “ocean layer” with just blue ocean, then I could stack it on to of the “expanding color layer” keeping the coastlines clean.Thanks for any tips
Johannes
