Activity › Forums › Adobe After Effects Expressions › Create marks for fast and slow layers
Posted by nechirawan kamaran on March 8, 2023 at 7:30 amCreate marks for fast and slow layers
Boston Cainfra replied 3 years, 6 months ago 2 Members · 2 Replies -
Boston Cainfra
March 12, 2023 at 10:41 pmHello there
You didn’t explain further on what you’re trying to do if it’s Adobe after effects or AE Expression but either of the two videos below will help you out
HAVE A NICE TIME
Boston Cainfra
March 12, 2023 at 11:12 pmHow to Make markings for fast and slow layers Favorite in After Effects,
The steps listed below can be used in After Effects to make marks for fast and slow layer favorites:
To mark layers as fast or slow, open the After Effects project that contains those layers.
Choose the layer you wish to designate as fast or slow.
The frame where you want to place the mark should have the current time indicator moved there.
Use your keyboard’s * (asterisk) key to add a marking for the current time.
Choose “Edit Marker” from the context menu by performing a right-click on the marker.
/ slowly
Double-click the mark in the timeline panel and enter the desired label to accomplish this.
To make the mark easier to see on the timeline, you can alter its color. To do this, “Marker Options” can be selected by right-clicking on the mark in the timeline panel. The mark’s color can then be changed from there.
If you need to generate marks for rapid or slow layers at any other periods in time, repeat these steps.
You may more easily explore your compositions and make necessary adjustments by utilizing marks to name and distinguish your fast and slow layers in After Effects.making layers’ markers.
“How to Make markings for fast and slow layers Favorite in After Effects,” by Isaac Oluwafemi
/ slowly
