Activity Forums Adobe After Effects Expressions Create Markers from External File.
  • Create Markers from External File.
    Posted by Henri Yates on October 21, 2021 at 10:17 pm
    Hello…
    I was wondering if there was a script or a way to create markers with comment retrieved from an external .txt file?
    It would pick the first line from the text file and use it first marker’s comment and the second line as the second marker’s comment and so on. It could place all markers one the same or each on its own layer (text, null, adjustment layer etc.).
    Thanks.
    Andrei Popa replied 4 years, 10 months ago 2 Members · 1 Reply
  • Andrei Popa
    October 22, 2021 at 7:11 pm
    You need some more information, as the time for each marker. IDK of such a script but it would not be that hard to do one. Here is one that puts a marker from your file at each second
    var myFile = File.openDialog("Please select markers file");
    putMarkers(myFile);
    function putMarkers(myFile) {
    var markers = [];
    if (myFile.open("r")) {
    var fileString = myFile.read();
    markers = fileString.split("\n");
    myFile.close();
    } else {
    alert(myFile.error);
    for (var i = 0; i < markers.length; i++) {
    addMarker(app.project.activeItem.selectedLayers[0], markers[i], i + 1);
    function addMarker(myLayer, comment, time) {
    var myMarker = new MarkerValue(comment);
    myLayer("Marker").setValueAtTime(time, myMarker);
