Activity Forums Adobe After Effects Create Loop Kaleida effect
  • Greg Gesch
    February 27, 2017 at 10:56 pm
    Hi Vugar, you could try the CC Kaleida effect. Mirroring=Starfish, scale the Size so that you only see one version, then keyframe the Center moving vertically up and down.
  • Richard Garabedain
    February 28, 2017 at 8:57 pm
    yes…do that kalediao scope thing on a comp..then add things to the comp…you will see that even the simplest animations come out pretty cooL
