Activity › Forums › Adobe After Effects › create kind of a burned effect
  • create kind of a burned effect
    Posted by Tielman Dewaele on March 21, 2007 at 11:22 pm
    Hello,
    I need to create a kind of burned effect on some shots in a movie im making.
    When you ever watched a surffilm you probebly seen it.
    Its like a sort of a burned effect on the edges of clips and the duration is only a couple of frames.
    Tryed something like cc burn, but it doesnt look right.
    I found a clip on the internet for example:
    https://www.youtube.com/watch?v=Jauwqv5gi_Q
    at +-1:21-1:30
    Help apriciated!
    Mr T
    Peace
    Tielman Dewaele replied 19 years, 6 months ago 5 Members · 5 Replies
  • Darby Edelen
    March 21, 2007 at 11:54 pm
    If I were you I’d play around with some color solids with different blending modes and masks applied to them. Maybe an adjustment layer as well that blows out the saturation a bit or alters the color. Then it’s simply a matter of animating the opacity of these layers drastically over a few frames. I’d recommend using a Null object and linking the opacity of the ‘burn’ layers to its opacity, you could also add expression that stutters the footage a bit based on the opacity of the Null object (if you like that old film look).
    This is assuming I understood the effect you’re looking for, the YouTube footage didn’t load all the way for me =)
  • Majorasshole
    March 22, 2007 at 3:19 am
    that stuff is shot on 16mm and 8mm film, so its not an effect its an actual defect in the film or processing.
  • Justin Productions
    March 22, 2007 at 4:01 am
    Here’s what I’d do:
    Create an Adjustment Layer and apply a Fractal Noise (no complexity at all) + Blur (5 to 7) + Ramp (red and orange) and play with the blending modes.
    The rest is only a matter of tweaking.
    Good luck.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • David Bogie
    March 22, 2007 at 9:06 pm
    You mean like someone opened the back of the camera or loaded the reels in daylight?
    bogiesan
  • Tielman Dewaele
    March 23, 2007 at 1:11 am
    Ok Guys thanks.
    I mested around with Fractel noise, CC toner, blurs, and the modes like Justin said.
    Its looks OK now.
    T
    Peace
