Activity › Forums › Apple Final Cut Pro › create individual sequences from favorites?
  • create individual sequences from favorites?
    Posted by Jason Brown on August 21, 2014 at 10:24 pm
    Any way to quickly set multiple in/out’s on a clip and generate individual sequences for each range? (or “projects” as they are incorrectly referred to) 🙂
    Charlie Austin replied 12 years, 1 month ago 2 Members · 5 Replies
  • Charlie Austin
    August 21, 2014 at 10:49 pm
    Create a new project, set favorite ranges, select all, hit Q or D to cut into project.
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Jason Brown
    August 21, 2014 at 10:54 pm
    I’m not sure you understand. I have 15 favorite ranges…want 15 sequences.
  • Charlie Austin
    August 21, 2014 at 10:59 pm
    [Jason Brown] “I’m not sure you understand. I have 15 favorite ranges…want 15 sequences.”
    Ah… I think you’d have to do each individually then.
    You can right click the favorite and make a new compound clip, but at some point you’d need to cut ’em into projects and break them apart. you can edit in a Compound clip just like a regular project, but it’s not the best idea….
  • Jason Brown
    August 21, 2014 at 11:27 pm
    Hmmm…if I can share a compound clip, it might work. I’m trying to export pieces of a digitized tape.
  • Charlie Austin
    August 21, 2014 at 11:37 pm
    [Jason Brown] “Hmmm…if I can share a compound clip, it might work. I’m trying to export pieces of a digitized tape.”
    Oh.. that’s easy, just select the range and share it via the share button or menu. 🙂
    See this thread for more info… https://www.fcp.co/forum/4-final-cut-pro-x-fcpx/21050-batch-export-favorites
