Activity Forums Adobe After Effects Expressions Create Effect controller (position) to control 3D layer Position
  • Create Effect controller (position) to control 3D layer Position
    Posted by Eden Exposito on November 28, 2012 at 5:25 pm
    Hi!
    I want create a layer effect to control 3d layer position like that https://d.pr/i/kxuK .I want maintain default layer position channel clean and add some expressions to this new position effect layer.
    I had tried something like that “app.project.activeItem.layer(1).effect.addProperty(“ADBE Slider Control”);” this add a normal slider controller…..but i want 3D point controller and use it to control layer position
    Somebody know?
    Dan Ebberts replied 13 years, 8 months ago 2 Members · 11 Replies
  • 11 Replies
  • Dan Ebberts
    November 28, 2012 at 6:32 pm
    Try this:
    app.project.activeItem.layer(1).effect.addProperty(“ADBE Point3D Control”);
    or this:
    app.project.activeItem.layer(1).effect.addProperty(“3D Point Control”);
    Dan
  • Eden Exposito
    November 28, 2012 at 6:40 pm
    Wow Perfect Dan!
    And for use those 3D point values to control position channel without add an expression in position channel? I want use this controller as position
    Thanks!!
  • Dan Ebberts
    November 28, 2012 at 6:43 pm
    I don’t think there’s any way to do that (except via an expression). Why don’t you want to use an expression?
    Dan
  • Eden Exposito
    November 28, 2012 at 6:51 pm
    I think that is more clean add custom expressions in custom channels instead default layer channels in this preset (by Videocopilot) Seems that they are doing that i attach a screenshot https://d.pr/i/2O0X
  • Dan Ebberts
    November 28, 2012 at 7:03 pm
    It looks like that’s just the Transform effect, which they have renamed to FX_Transform. If you were willing to create your own plug-in version of the Transform effect I think you could (as of CS5.5) add a 3D point control, but that would be a lot to bite off.
    Dan
  • Eden Exposito
    November 28, 2012 at 7:18 pm
    wooh!. Well I only want add Transform effect with name changed too 😛 maybe this it’s more simple that I thought to do. Do you know the script line to do it?
    Thanks Dan for your rapid responses!!
  • Dan Ebberts
    November 28, 2012 at 7:49 pm
    Try this:
    var myEffect = app.project.activeItem.layer(1).effect.addProperty(“ADBE Geometry2”);
    myEffect.name = “FX_Transform”;
    or this:
    var myEffect = app.project.activeItem.layer(1).effect.addProperty(“Transform”);
    Dan
  • Eden Exposito
    November 28, 2012 at 8:09 pm
    Wow! Perfect.
    How you know the property names “ADBE Geometry2” … “transform”.. etc? Where I can consult it? Seems exists a list of those effects ready to use..
    Thanks!!
  • Dan Ebberts
    November 28, 2012 at 8:16 pm
    Just Google “After Effects match names”. That will lead you to a couple of lists. I always just use Jeff Almasol’s wonderful rd_GimmePropPath script available at his site (redefinery.com_)
    Dan
  • Eden Exposito
    November 28, 2012 at 9:53 pm
    Great utility!!
    As I expected
    myEffect.name = “Transform”;
    Give me a 2D dimension capabilities only (Adobe dont think about 3D layers?)
    With GimmePropPath i can see that position is: layer(1).property(“Transform”).property(“Position”) but
    var myEffect = app.project.activeItem.layer(1).effect.addProperty(“Transform”).property(“Position”);
    Dont work, maybe a property can not work like an effect?…or script line is wrong
    other questionis if I can add specific parameter of Transform effect instead invoke all effect?
