Activity › Forums › Apple Final Cut Pro Legacy › create custom transition using keyframes?
  • create custom transition using keyframes?
    Posted by Elise London on May 6, 2011 at 5:35 pm
    Hi — I am trying to create a custom transition using keyframes, in order to apply these same keyframes to hundreds of clips.
    I have tried to just copy/paste attributes for the keyframes, but that does not work. Because all of my clips are different lengths, they keyframes are distributed differently from clip to clip. No good.
    So this is why I am trying to just take my keyframes from one clip, create a transition, and apply those exact same keyframes to the rest.
    Is this possible? Thanks so much!!
    Elise London replied 15 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    May 6, 2011 at 6:04 pm
    Uncheck “Scale attributes time”.
    rafael
    http://www.nagavideo.com
  • Frank Giardina
    May 6, 2011 at 7:41 pm
    You Rock Rafael!
    Frank Giardina
    17 Video Production
  • Elise London
    Wow, thanks! I can’t believe I didn’t see that checkbox. Voila!
    Except …
    In each clip I have a transition happening at the beginning and end of every clip. So now that I have pasted the keyframes, the outgoing transitional effect happens at the wrong time on the rest of the clips, since they are of different lengths.
    Thus, in this case, it actually would be much better to be able to create a custom incoming/outgoing transition. That way I could just apply it at the beginning and end of each clip, regardless of the clip’s length.
    Is there a way to do this?
  • Garrett Evans
    May 6, 2011 at 8:56 pm
    What if you put an Add Edit at the right time and applied it there?
    MacPro OSX 10.6.6 2×2.26 QCIX 10GB 1066MHz DDR3 FCP7.0.3/FCS3
    FCSvr1.5 Xsan2.2 DotHill 24TB QlogicSANbox 8GB ATTO 8GB
  • Elise London
    May 6, 2011 at 9:19 pm
    Yeah, that would work … except for the fact that I cannot slice the clip at all. It is actually a ‘countdown’ generator, and if I slice it, then the time on it would be reset. The countdown needs to stay fluid the whole time.
    Thus — the desire to just be able to drop a transition on the front and back end of the clip.
  • Garrett Evans
    May 6, 2011 at 9:20 pm
    Ah, yeah…bummer…can you nest a countdown? Or export it and bring it back in…
  • Elise London
    May 6, 2011 at 9:28 pm
    No … I have hundreds, maybe thousands of these to do, so I don’t have the time to do all that.
    What I need is just to be able to create a custom transition from keyframes, then apply it throughout.
    I know that you can create custom transitions from filters, so why not from keyframes? So far I have done lots of research, found nothing. But it makes no sense! Why shouldn’t you be able to create a transition from keyframes?! 🙂
