Activity Forums Adobe After Effects create cloud movements and animation in AfterEffects
  • create cloud movements and animation in AfterEffects
    Posted by Allen on June 13, 2006 at 12:49 am
    I need to create some realistic cloud animation in AfterEffects and I’ve try using Aurora Sky as well as Trapcode Particular but none of them produce the effects that I want. I need “indivdual Puffy cloud than move around in the same spot” ans I can animate the xy prosition later on
    I’ve got good stills of puff cloud with Alpha channel but don’t know how I could create a realistic movements, or does any one knows other AE plugin that let you create custom shape and custom movements of clouds
    please help
    Allen
    Bausdtown replied 20 years, 3 months ago 6 Members · 5 Replies
  • Andrew Kramer
    June 13, 2006 at 1:55 am
    Particular could be an interesting start. search for trapcode people in google and there is a great site with a cloud example.
    But if you want anything photoreal you’ll need after burn and a 3D program. there’s always stock footage…
    Andrew
  • Vince Becquiot
    June 13, 2006 at 4:53 am
    I have not seen any realistic clouds made in AE without a 3rd party plugin.
    I think “Particle Illusion” may be something worth looking into.
    Or you could dive into Cinema 4D 😉
    Cheers,
    Vince
  • Ebarfield
    June 13, 2006 at 2:10 pm
    You might give this tutorial a look…don’t know if you could apply this principle to your still shot to put it in motion or not.
    https://studio.adobe.com/us/tips/tip.jsp?p=1&id=100775&xml=aft65sddisplace
    good luck,
    egb
    “deja vu all over again” — Yogi Berra
  • Al
    June 13, 2006 at 3:25 pm
    i’ve used particular to create realistic wispy/smokey clouds, though not puffy clouds… i can’t see how you’d be able to use your stills convincingly — for this work you’ll need a particle generator. if particular won’t do the job, then i’d go 3D.
  • Bausdtown
    June 14, 2006 at 1:43 pm
    Tinderbox also has a nice sky & cloud-simulation.
    No nation – no border!
    Fight Law & Order!
