Activity › Forums › Apple Final Cut Pro Legacy › Create border on circle filter
Posted by Leonard Frankford on November 30, 2009 at 5:06 pmI need to make a colored border around the circle using the circle shape filter. I see border is not a selectable parameter in the filter. When I select Borders it only creates a border around the entire frame. How do I create this switcher effect in Final Cut?
Leonard
Tom Matthies replied 8 years, 11 months ago 10 Members · 12 Replies -
Rafael Amador
November 30, 2009 at 5:17 pmMy FC is rendering, so I can not have a look.
There is not any “Edge Feather” or so?
You can always apply a Gaussian Blurs, but, carefull, just to the RGB channels.
Perhaps also the “Mask Feather”?
rafael -
Leonard Frankford
November 30, 2009 at 5:26 pmWhat I am talking about is a colored border, with the ability to adjust the color and thickness of the border, just as you might with a switcher effect.
Leonard
Steve Cohen
November 30, 2009 at 5:35 pmThe border filter in FCP is awful. It will only place a border around the entire raster, so if you crop it or use a circle mask it doesn’t do what you are looking for,
1 option is to put a colored matte below it and then copy the circle mask from the first clip onto the color matte and then adjust it so it is a little bit larger.
Steve Cohen
Senior Editor
O2 Media Inc. -
Rafael Amador
November 30, 2009 at 5:40 pm“Oval Iris” (Transitions) is a circular wipe. You can put a colored border if you want.
rafael -
David Bogie
November 30, 2009 at 7:05 pmI think there are a bunch of freebies from the likes of CV and DH that have excellent border options for wipes.
bogiesan
Arnie Schlissel
November 30, 2009 at 8:36 pmThis is what makes Photoshop and Illustrator such valuable tools for film makers. It’s very easy to make a circle or oval in either of those programs and then make a stroke around it. Or just make the stroke.
BTW, you can do this in Motion using it’s vector shape generator. Refer to your Motion manual for more info.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Kevin Monahan
November 30, 2009 at 10:00 pmUse Generators > Boris > Vector Shape. That has what you need. Also, Motion of course – but why leave the app?
You can actually create a border with the circle generator, however, it is not straight forward: involves 2 more layers, nesting and a travel matte luma comp mode.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Andy Mees
December 1, 2009 at 12:37 amyou can do this with my free Region Blur plugin too, just set edge to frame, blur to zero and the tint color and amount as needed … bear in mind that with my plugin the frame thing works best on square pixel comps
Brad Kopp
December 1, 2009 at 4:55 pmI would do it in Live Type using a zero or O
Moto Guzzi rider
dog lover w/wife, Ex & 3 kids -
Leonard Frankford
December 1, 2009 at 5:27 pmThat’s the one that works for me. I have to add the Luma Keyer to make the video appear through the circle. But that’s the effect I was looking for, without leaving FCP, as you say. Thanks.
Leonard
