Activity Forums Adobe After Effects Create Black, not Alpha
  • Create Black, not Alpha
    Posted by Steve Johnson on December 21, 2007 at 3:19 pm
    Hello,
    I think I’m loosing my mind. I haven’t worked too much with 3d layers in the past. I have a composition with many 3d layers aligned in z-space, and I need to fade many of them to black as they get closer to the floor. however, when i mask a layer’s bottom, it looks black, but that black is acually an alpha channel, so i get transparency. How can I in after effects create a black non-transparent fade on a layer?
    CS3 – Mac
    C4D
    Steve Johnson replied 18 years, 9 months ago 4 Members · 5 Replies
  • Steve Roberts
    December 21, 2007 at 3:30 pm
    Place a fullscreen black solid (2D) at the bottom of the timeline?
  • Steve Johnson
    December 21, 2007 at 3:34 pm
    This will make me a black backgound, which when rendered would be an alpha channel. This would be ok, but actually I have a background plate that I’m already using. Imagine 3 layers arranged behind each other with the 4th layer being some stock footage. I need to gradient to black the bottom half of layers 1-3. Doing this on the layers with a mask or anything that colors the layer black makes the bottom half of my 3d layers transparent and I can see my background through them, when i really want them to be black.
    CS3 – Mac
    C4D
  • Don Sciore
    December 21, 2007 at 3:49 pm
    Steve,
    A full screen black “solid” won’t render as an alpha channel. A Black “background” will if you tell it to in render queue. They are different.
    Use Steve’s suggestion and parent a black solid to each of your masked layers. This will not be transparent.
    Good Luck.
    Don
  • Darby Edelen
    December 21, 2007 at 4:32 pm
    At first it sounded like you wanted to fade the layer to black, now it sounds like you want a ramp on the layers. The implementation will change depending on what it is you really want to do, but I would recommend either a Generate > Fill effect using a Black Fill that you can animate the opacity of (for fading to black) or parenting a solid with a Generate > Ramp effect applied set to the Multiply blend mode.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Steve Johnson
    December 21, 2007 at 6:27 pm
    Ahh, the Ramp effect has helped dramatically. That was the ticket. Doh!
    Thanks all.
    -steve
    CS3 – Mac
    C4D
