Activity › Forums › Adobe Illustrator › Create anchor point automatically at two intersecting paths
  • Vincent Rosati
    March 8, 2012 at 12:32 am
    Selecting all of the objects and Window / Pathfinder / Outline might work for you. Other than that, the only thing I can think of is to turn on snapping and use the Scissor tool.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Anil Agarwal
    March 8, 2012 at 1:27 am
    Worked perfectly as described. Thank you, Vincent.
  • Frances Milne
    August 18, 2015 at 8:28 am
    Thank you Vincent! – I’d been trawling trying to find something to create a simple triangle diagram with no success and this worked quickly and easily.
