Activity Forums Maxon Cinema 4D Create An Object With Edges, No Faces
  • Create An Object With Edges, No Faces
    Posted by Ace Billet on July 8, 2013 at 7:17 pm
    I’m trying to create a pyramid that’s built only of its edges,
    like a tent frame.
    How do I remove the polygons and create a frame ?
    Is there a way to make the edges width controllable ?
    this is a reference for the edgy look, forget about the lizard !
    Cheers
    Nolan Scott replied 13 years, 1 month ago 2 Members · 1 Reply
  • Nolan Scott
    July 9, 2013 at 2:58 am
    Either, use an Atom Array…
    Or, make your Pyramid Editable / select all edges / Edge to Spline.
    Create a Rectangle (or else) in a suitable size.
    Drag the Rectangle (first position) and the Pyramid.Spline into a Sweep Nurbs.
    Adjust the Sweep Nurbs- / Rectangle-settings to your liking..
