Activity Forums Maxon Cinema 4D Create an OBJ of the Earth mainland to use with Plexus in After Effects
  • Create an OBJ of the Earth mainland to use with Plexus in After Effects
    Posted by Scott Green on March 5, 2015 at 2:31 pm
    We all know that you can create points from an OBJ model using Plexus in After Effects right? But what if you just wanted the Plexus effect to cover a sphere so it looks like the mainland of the Earth?
    I just thought about creating a sphere in C4D with loads of segments, making it editable, applying a texture map of the mainland and deleting all of the verts that are in the sea – that sounds like a long process and I’m sure somebody out there has an easier solution.
    Any suggestions?
    Splurj Creative, Video Production, Motion Graphics & Animation in Manchester UK.
    Cassius Marques replied 11 years, 6 months ago 2 Members · 1 Reply
  • Cassius Marques
    March 5, 2015 at 8:45 pm
    import a vector as a path, extrude with regular grid creating the vertex density you need, delete sides + back then apply a sphere modifier.
