Activity Forums Adobe After Effects create an a/b transition
  • create an a/b transition
    Posted by Scott Tupper on November 6, 2006 at 10:27 pm
    I want to create a re-usable a/b transition, meaning alpha channel for both incoming and outgoing video to be used in FCP. My graphic element fills the screen vertically and want that to use that as the wipe edge.
    I have seen these canned effects before, can AE 7 do this?
    Steve Roberts replied 19 years, 10 months ago 2 Members · 2 Replies
  • Scott Tupper
    November 7, 2006 at 12:15 am
    The problem I am running into is that clip A needs to keep playing as the element wipes across it revealing clip B which is also running. Almost like I need a mask to cover up clip A and reveal clip B. Does that make sense?
    I know alpha channel.
  • Steve Roberts
    November 7, 2006 at 1:12 am
    What does your graphic element look like, and what do you expect it to do during the transition?
